Installing fogs, what else do I need
Old Aug 30, 2008 | 08:49 PM
bhays's Avatar
Default Installing fogs, what else do I need
I just bought a pair of fog light assemblies on ebay to install on my base roadster.
http://cgi.ebay.com/ebaymotors/ws/eB...MEWN:IT&ih=006
They are just the assembly, no bulbs.
So, what else do I need to wire these up (I have read the threads on wiring in the switch and think I can handle that end). Do I just need a pair of 9006 pigtails like these, or do I need something else?
http://store.summitracing.com/partde...art=pco-5462pt
Old Aug 30, 2008 | 08:51 PM
nox1s's Avatar
Default Re: Installing fogs, what else do I need
Sorry I can't help you with the installation, but you bought the old style.. :'( The little silver cap is eventually going to pop out and bounce around on the inside of the foglight assembly..
Old Aug 30, 2008 | 09:44 PM
bhays's Avatar
Is there anything I can do before I install them to help with that?
Old Aug 31, 2008 | 05:57 AM
acrispy1's Avatar
I have an 04 and never had a problem the cap popping off.
Old Sep 9, 2008 | 07:34 AM
nox1s's Avatar
It most likely will, eventually. Many many members have had this issue, and taken them to the dealer. Result = new fog lights, with a new style. The new bulbs do not have these caps. I took a screwdriver to mine and manually popped out the cap..and got new ones
Old Sep 9, 2008 | 02:55 PM
maxcichon's Avatar
Oh, you dirty bugger!
I did too.
Old Sep 9, 2008 | 03:20 PM
Jeep2Xfire's Avatar
I have an '05, driver fogs cap popped off about a week ago.
Old Sep 10, 2008 | 07:52 AM
beasticles's Avatar
I have an '04 - never had any popping off of the caps. However about two months ago my right fog cracked clean across the middle. Has yet to break but I am planning on upgrading to the new ones when I have the time and funds. I am not sure if the new versions have a different type of plastic?
To be honest though I would have boughten those fogs you got on ebay at $50 a pop too!
Old Sep 10, 2008 | 08:03 AM
bhays's Avatar
Then a week later, a set of the new style went cheaper, though.
Old Sep 24, 2008 | 10:28 PM
Waynesworld's Avatar
I did the same thing you did. Have you installed the lights yet?
I think it should be, on a scale of 1-10, A 7.
The wireing is the trick. I think I can use the stock switch?
Any tips???
Mike OD
Sep 23, 2016 07:00 AM
Franc Rauscher
May 9, 2016 12:04 PM
UNDER PSI
Nov 1, 2015 09:39 PM
bbsrt6
Sep 19, 2015 11:21 AM
maxcichon
Sep 4, 2015 12:50 PM
