Engine bay lighting by Oznium
Old Aug 23, 2009 | 12:49 PM
tburris's Avatar
Default Engine bay lighting by Oznium
Pic's of under the hood with 1 Oznium High Intensity LED (Red) Colored Spot light, Great for the shows
Interior Lighting pic's will be posted next week.
http://www.oznium.com
Old Aug 24, 2009 | 11:41 PM
tburris's Avatar
Default Re: Engine bay lighting by Oznium
Here's the pics of the interior by Oznium
LEDs - underbody kits, cathodes, flexible LED strips, dome lights
Old Aug 25, 2009 | 05:26 AM
danimal's Avatar
Pic's of under the hood with 1 Oznium High Intensity LED (Red) Colored Spot light...
Where did you place the LED to get that kind of coverage?
Old Aug 29, 2009 | 06:45 PM
tburris's Avatar
On the crossmember just below the hood latch drilled 2 small pilot holes and screwed it in place just enough angle to cover the entire engine bay, this a a high intensity LED flood light gives a 120 degrees of coverage check out there website.
Old Aug 29, 2009 | 10:04 PM
32krazy!'s Avatar
you mounted it under the radiator brace? and it lights the brace up on top? do you have a daylight foto of the mounted lite? its great lighting and i would love to copy your design!
Old Aug 29, 2009 | 11:47 PM
Rv Xfire08
Guest
Posts: n/a
WOW,I like it better than the way we did ours.We have red leds under the engine cover.But does not light up as good as yours.
Old Aug 30, 2009 | 12:59 AM
tburris's Avatar
Let me rephrase what I said a little better.. Its mounted on the underside of the hood just back from the hood latch on a crossmember. I cut a hole to match the light in the hood liner. There is an angle on the crossmember that works perfect.
Old Aug 31, 2009 | 08:23 AM
32krazy!'s Avatar
makes more better sense now!! not sure if i want to go this route but thanx for the website. i found a bunch of stuff at very reasonable prices
jgreen
106
Sep 18, 2017 11:46 PM
wruss
Feb 8, 2017 01:05 PM
northwest_crossfire
May 30, 2016 05:19 PM
BrenLW
Aug 5, 2015 04:53 AM
axnguyen
Jul 21, 2015 11:41 AM
