Dome Map Light question
Old Jun 2, 2010 | 11:32 PM
xscape's Avatar
Default Dome Map Light question
Well long story short one of my dome lights is out so i go to auto zone get the light pull the plastic and take the old light out, well then i try to put the new light back in but it seems that there is no actual socket. I then pull out the whole piece and i still see no socket...so is there a part number for that or will i just have to live with it?
-Austin
Old Jun 3, 2010 | 04:22 PM
Default Re: Dome Map Light question
-Austin
Austin, I am having trouble figuring out exactly what you mean by your statement. I would recommend you check out the 'sticky' in the lighting section, it walks through replacing the map light (dome) bulbs with LEDs but it should show you everything you need. Hope this helps.
John
Old Jun 3, 2010 | 04:35 PM
-Austin
If the end of the new bulb looks like the end of the old bulb there should not be a problem.
Old Jun 3, 2010 | 04:46 PM
xscape's Avatar
Maybe a picture would help?
Old Jun 3, 2010 | 05:01 PM
xscape's Avatar
Okay the first picture is of the light which works, second one there is a part missing.hope this clears up the confusion.
Old Jun 3, 2010 | 06:30 PM
former NXMX5's Avatar
...pull the plastic and take the old light out...
wasnt it there when you pulled the old light out? maybe it got unhinged and is stuck above the plastic mount?
Old Jun 3, 2010 | 07:51 PM
MikeR's Avatar
I agree.... I think you just need to pull the screws holding the assembly in and pull it out.... I also see that the side that has a socket is craked on both sides.... be carefull not to break it further......
Old Jun 3, 2010 | 08:30 PM
rfors777's Avatar
The tan piece in picture 1 is the socket. You removed it when you untwisted the bulb, and it is still on your old bulb. Pull it off and insert your new bulb into it. Then twist it back on.
If you lost it, go here:
http://www.superbrightleds.com/cgi-b...0_sockets.html
Get the T10S-TW Twist Locks for $1.19 a piece.
Old Jun 3, 2010 | 09:12 PM
T10mm Wedge Base Sockets Specifications
You learn something every day on this site.
Never knew it looked like this before. The pictures really make the question answerable.
Old Jun 3, 2010 | 11:32 PM
xscape's Avatar
thanks for the quick replies, last night i took out the entire piece but did not see the socket. Today i took it out again and started reaching around in the headliner and it was about 2 inches in the headliner. Needless to say it is fixed and working great.
-Austin
PNA
Aug 30, 2024 02:06 PM
Adrian_X
Nov 9, 2017 08:49 AM
axnguyen
Jul 21, 2015 11:41 AM
KwehCat
Jul 16, 2015 04:48 PM
tom2112
Jul 8, 2015 08:13 PM
