CrossfireForum - The Chrysler Crossfire and SRT6 Resource (https://www.crossfireforum.org/forum/)
-   Exterior & Lighting (https://www.crossfireforum.org/forum/exterior-lighting/)
-   -   Help! Driver's Side Lights Out! (https://www.crossfireforum.org/forum/exterior-lighting/51102-help-drivers-side-lights-out.html)
Erichenderson02 Jul 11, 2011 11:31 PM
Just went out and turned on my headlights, but my driver's side brake light and parking light will not turn on. Brake light works when I hit the pedal only.
Passenger's side brake light is acting normal (dim illumination when headlights are on, bright when I press the brake pedal), and the parking light on that side is fine.
I checked all of the fuses (visually) and they were all fine.
I have no idea what would cause only one side's lights to go out...
Any help would be great.
Thanks,
Eric Henderson
robby363 Jul 12, 2011 05:02 AM
Re: Help! Driver's Side Lights Out!
1 Attachment(s)
Did you check the bulb.:confused:Check #10 fuse. It's a brown 7.5 amp located here.
Erichenderson02 Jul 12, 2011 01:47 PM
I checked the bulb but didn't even know there were fuses in that location. :rolleyes:
I'll report back shortly.
Also, both sidemarkers are out in addition to the parking light and tail light on that side.
Thanks,
Eric Henderson
Erichenderson02 Jul 12, 2011 01:51 PM
Okay so,
It was that fuse.
Thanks a ton! I was pulling my hair out all night trying to figure out what the problem was.
Off to autozone to get some new fuses.
Thanks again!
-Eric :D
© 2026 MH Sub I, LLC dba Internet Brands
