HID in high beams
Old Apr 23, 2013 | 05:39 PM
2008XF's Avatar
Default HID in high beams
I want to put HID on my car but dont want them on during the day for DRL, so I was wondering if i put them in high beams , can i adjust them to go lower?
Old Apr 23, 2013 | 06:50 PM
Adrian_X's Avatar
Default Re: HID in high beams
From what I know the headlight assembly will not allow you to aim the highbeams lower by themselves. Also, you don't want to put HID systems in the highbeams because of their warm up and cool down time. A halogen bulb reaches full brightness instantly almost, vs HIDs which require anywhere from 4 to 15 seconds to fully warm up to their highest brightness.
Old Apr 23, 2013 | 10:22 PM
JesseJamessrt6's Avatar
This is all true, good advice.
Old Apr 23, 2013 | 10:44 PM
Mrmiata's Avatar
If you were creative enough.. couple relays.. some spade ends.. run leads from lows connector to high bulbs (becomes DRL in high beam position in headlight) with relay - normally closed. Add HID to low beam position fed by high beam circuit which also would be wired to open high beam DRL circuit on the relay. Your high beams would be normal H7 bulbs but you wouldn't have the lows on with it. Makes sense in my head.. LOL.
Old Apr 26, 2013 | 01:33 PM
Sik Srt-6's Avatar
The only way to properly disable the DRL's in our cars is to change out the headlight switch assembly with a US version. A few of the cnd crossfire owners should have some of the non DRL moduels laying around.
And as a fyi for us canadian owners, DRL's are only a requirement for importation into Canada, once the car is here and paperwork done it doent need to be operational. The only provice that has mandated "a operating DRL system" is Nova Scotia. I found out this tidbit last week
Old Apr 26, 2013 | 02:46 PM
Yes, this was pointed out to us some time back by TonyGG, the music man.
It is amazing that we have people in position to pass useless rules, spend a fortune on it and then it is worth diddly squat.
Old Apr 26, 2013 | 03:15 PM
Sik Srt-6's Avatar
Yes i totaly agree!
The concept for DRL's in northen climates makes sense, seeing that days are shorter, and darker and such, but the method of implementing it is a total screw up. The fact that the headlights are used as a DRL is the major flaw. Numerous times ive seen cars going down the hwy, without any tail lights on because of the DRL system on a vehicle without "auto on" headlights. The driver doesnt know hes in DRL mode, and not regular beam mode. Most of the new cars the stupid dash lights up even when in DRL mode. It not easy to spot a car on a dark hwy without tailights.
I dont want to side track the thread much but it must said
Old Apr 26, 2013 | 07:09 PM
waldig's Avatar
Talking Re: HID in high beams
I have HID in both lamp sets, not an issue, they flash when turned on and the driving with 4 is really quiet the experience. I would not go back and do the h7 for anything. 35 hids are really the ticket, but I run in a different track than some. Enjoy
Weekend Woody
Weekend Woody
Weekend Woody
Weekend Woody
Valk
Jul 12, 2021 09:49 PM
aerobluehal1
Canada
19
Oct 13, 2018 09:47 AM
Oct 1, 2015 01:42 AM
ala_xfire
Sep 28, 2015 05:51 PM
Franc Rauscher
Sep 20, 2015 09:35 AM
