Interior dome light
The dome light and cargo light are common to fuse 9 in the under hood accessory block.
In automatic mode, the ground to cause them to light is supplied by the BCM ( Body Control Module ) on pin 18 of connector 4.
The BCM is reading all the door and lift gate / trunk switches ( via the CLP - Central Locking Pump ) in order to determine if the lights should be on or off, so I would suspect one of those 3 would be the culprit.
Slam it and check the bulb again.
This has been the solution for some people here.
BTW, the switch for the trunk latch is built into the catch mechanism ......
chrisIowa
Jul 29, 2015 03:50 PM
ricardo 53
Jul 21, 2015 07:49 AM
