Headlight Low-Beam Bulb CLIP problem...
Old Nov 9, 2013 | 11:37 AM
NjRichieRich25's Avatar
Default Headlight Low-Beam Bulb CLIP problem...
Great posts on headlight issues guys! Very helpful!
Except my dumb *** dropped the headlight low beam bulb clip INTO the headlight housing!
What should I do? Could not get out the clip even with a magnet!
Is my next option to take out entire headlight housing???
Old Nov 9, 2013 | 02:38 PM
syfi's Avatar
Default Re: Headlight Low-Beam Bulb CLIP problem...
I used a snake grab to get mine out...
I learned the hard way to tie some string to the clip next time.
Amazon.com: Reaching Tool 24" Claw Pickup Tool Snake Grabbing: Everything Else Amazon.com: Reaching Tool 24" Claw Pickup Tool Snake Grabbing: Everything Else
Old Nov 12, 2013 | 10:12 AM
Thanks a bunch Syfi! Worked like a charm!
Old Nov 12, 2013 | 03:21 PM
syfi's Avatar
No prob Rich. I've done so many light exchanges now that I can almost do it blind. I now have a snake neck mini led lamp with a magnetic base that's perfect for putting light inside the housing. I like to just take the clip off instead of fiddling with feeding the connector ends through the clip when installing HIDs. A small inspection mirror helps to locate the clip nubs and I now use a bent-nose hemostat to install the clip. The very first one i did where the clip came off took me a couple hours of cursing to get it back on by hand. Now it's off & on in seconds.
smfrycruzr
Jul 17, 2023 05:33 PM
RiderJC
Sep 7, 2015 11:19 PM
jaesa
Sep 7, 2015 01:50 PM
davidc90
Sep 6, 2015 10:37 PM
maxcichon
Sep 4, 2015 12:50 PM
