Paint Code Location
Old Nov 9, 2016 | 10:03 AM
boobles37's Avatar
Default Paint Code Location
Anyone help with where I would find the paint code please?
It's on my 2004 Coupe RH drive. Have looked inside drivers door but all it mentions is tyre pressures etc. Have also looked within the engine area & still can't see anything other than the VIN number.
Old Nov 9, 2016 | 10:53 AM
Default Re: Paint Code Location
It is supposed to be on the frame somewhere, last I heard someone had found it behind the rear bumper cover. I have never seen and cannot confirm the truth of this.
There is a PDF showing the paint code, all reds are the same except for the actual name which varies slightly.
Click on the Index ... below and look in the body section.
Old Nov 10, 2016 | 08:33 AM
boobles37's Avatar
You could be absolutely right about the rear bumper! Many thanks......
Am I right in saying that the "light silver" is actually called sapphire blue or something?
Old Nov 10, 2016 | 10:04 AM
Sapphire Silver Blue (SSB) actually.
Old Nov 10, 2016 | 10:22 AM
boobles37's Avatar
Thank you.
Old Nov 10, 2016 | 10:32 AM
Thank you.
Paint codes. CLICK
