Load resistors for front blinkers?
Hello, I have LED turn signals both front and back. I’m beyond sick of the hyper flash, but my confusion about the load resistors comes from the front. How the heck do you wire these things up if it’s only a socket with no wire connection? Any help would be greatly appreciated. (Ps I tried searching but could not find anything)
Re: Load resistors for front blinkers?
You would connect the proper sized resistor from pin 1 of each headlight connector to ground.
I do not know what the proper value for the resistors is.
Even though pin one is not labeled in the above diagram, it IS the input for the turn signal bulb.
