Error Code
Old Sep 25, 2025 | 02:07 AM
Brian P's Avatar
Default Error Code
I noticed yesterday that I had an error light that, well, looked like a light. I will pull out my code reader if I have to. I was just hoping that someone knew what it probably meant.
Thanks,
Brian
Old Sep 25, 2025 | 06:03 AM
DeKalb's Avatar
Default Re: Error Code
if it looks like a light bulb it is telling you there id a bulb out , check marker lights as well as tail, brake, turn signals front and rear , head lights and fog , don't forget rear plate and backup lights ,,, you may need a helper or find a big store window to use
Old Sep 25, 2025 | 05:43 PM
That won't help. Opening your owner's manual and reading about the instrument panel WOULD help.
Old Oct 3, 2025 | 11:48 PM
Brian P's Avatar
Default Re: Error Code - bulb
Alright, I figured out that the drivers light closest to the latch is out. Is there an easy way to figure out the part number? I’ll probably just get two for when the other side goes out.
Thanks,
Brian
Old Oct 4, 2025 | 01:53 AM
Thanks,
Brian
If you mean the headlights, they are all H7 bulbs. (Headlights and high beams).
Old Oct 4, 2025 | 08:41 AM
zip439's Avatar
H7 but get only 55W If the wattage isn't right you will melt plastic and cause wiring to get brittle; Thus do not use HID light bulbs.
Sylvania makes a reasonable priced H7 bulb available at most auto parts stores "SYLVANIA SilverStar® ULTRA "halogen bulbs, or Needswings sells PIAA which are excellent.
Old Oct 4, 2025 | 09:45 AM
If he is describing the high beam, he will only have the warning light when the high beams are on.
I wonder if he means the tag/license plate light?
IF so, NOW would be a great time to order two of the blue-white LED modules - they really dress up the car at night!
Old Oct 4, 2025 | 07:06 PM
I've got that outside warning light popping up every once in awhile. Turns out it is a license plate bulb that won't stay tight in its clamps. Gets loose from closing the Hatch every once in awhile.
Old Oct 4, 2025 | 11:08 PM
I had LED lights in my license plate sockets. One night after being at a car show I had no dash lights. It turned out that one of the chips fell out of the LED and caused a short. Knocking out the dash lights and license plate lights.
They were cheap garbage bulbs and closing the trunk was the cause of the failure. I only use the regular type Sylvania bulbs in there now.
Old Oct 4, 2025 | 11:41 PM
Brian P's Avatar
Wow, that’s crazy. I’ll try ordering the Sylvania bulbs from Amazon. Are the rear bulbs also the H7?
Old Oct 5, 2025 | 12:10 AM
Download the owners manual here in the download section, all the bulb numbers (and where they are located) are listed.
Old Oct 5, 2025 | 05:49 PM
Here's the Exterior Bulb listing out of my 2007 Owner's Manual:
Old Oct 5, 2025 | 08:31 PM
Brian P's Avatar
Are these all Sylvania bulb numbers? I appreciate you posting this for me.
Brian
Old Oct 5, 2025 | 10:15 PM
Brian
The bulb numbers should apply to most manufacturers. You should be able to get them at your local auto parts store. They should be able to confirm the numbers for you.
Good luck!
Old Oct 6, 2025 | 08:14 AM
Brian
I would strongly recommend that you download a copy of an Owner's Manual from the Crossfire Documentation Forum Page. There are 3 listed: 2004-2006 for Coupes; 2005-2006 for Roadsters. There is also an SRT-6 copy which is unique versus the NA (Normally Aspirated) Crossfires. There is essentially the same info in all the manuals.
You need to also save the link to the Forum Documentation webpage (or bookmark the webpage) . It always comes in handy.
Old Oct 7, 2025 | 06:19 PM
I swapped out the LED bulbs for the license plate lights with conventional 6418 bulbs. I did a little comparison while I was doing this work. Turns out the LED bulbs were just slightly shorter than the conventional 6418 bulbs (naked eye probably wouldn't see the difference). I figure it was enough of a difference that the LED bulbs was slipping out of the plastic retainers in the light fixture with enough deck lid closures over time. That resulted in the LED bulb losing contact with the bulb holders & generating the failed exterior light warning light in the instrument panel.
Old Oct 8, 2025 | 02:10 AM
They do make LED assemeblies to replace the stock lens and housings. I'm just sticking to the standard bulbs though.
Old Oct 8, 2025 | 04:53 PM
They do make LED assemblies to replace the stock lens and housings. I'm just sticking to the standard bulbs though.
Yeah - I've got a pair of the new housing & bulbs in my Crossfire Parts bin.
CabinIsle1
May 30, 2024 09:44 PM
Bob54
Aug 5, 2023 06:08 PM
jasonk931
Mar 25, 2022 06:22 PM
austinbarrylee
Dec 11, 2013 10:10 AM
Vmax01
Apr 27, 2009 11:05 PM
