Crossfire AC Users: Summertime!
Old May 22, 2009 | 08:44 AM
amcordo's Avatar
Default Crossfire AC Users: Summertime!
Just a reminder to get back in the habit of hitting you recirculation button after you turn off your car to dry out the AC system. It'll prevent that bad smell from coming out of your AC system.
Old May 22, 2009 | 08:53 AM
Romio's Avatar
Default Re: Crossfire AC Users: Summertime!
but it can also kill your battery. With the fan still running without the engine. It doesn't shut off automaticly either. So if it runs all night it will
Old May 22, 2009 | 09:07 AM
Iamfink2's Avatar
It will shut down automatically after 30 minutes or if the battery starts to runs low.
Residual Engine Heat Utilization (REST)
With the engine switched off, it is possible to
continue heating the interior for a short while.
Air volume is controlled automatically. Select a
temperature for each side of the passenger
compartment. Set the air distribution control switch to
the desired position.
To select, turn the key in the ignition switch to the ACC
or the OFF/LOCK position or remove. Press the recirculation
button. The indicator light in the button illuminates.
This function selection will not activate if the
battery charge level is insufficient.
To cancel, press the recirculation button. The indicator
light in the button goes out. The system will automatically
shut off if you turn the key in the ignition switch to
the ON/RUN position, after approximately 30 minutes,
or if the battery voltage drops.
Old May 23, 2009 | 11:02 AM
amcordo's Avatar
Mine shuts off automatically. If yours doesn't you should consider getting it checked on as this is the only sure-fire way to avoid mildew and bacteria growth in the AC system.
rayth
41
Jul 31, 2019 04:02 PM
RED DOG
-C-I-C-C-I Discussion
25
Jul 26, 2015 07:25 AM
MiamiTVR
Jul 14, 2015 01:26 PM
ultrajim49
17
Jun 27, 2015 12:20 AM
MJPowers
Jun 8, 2015 02:34 AM
