Inside air fan has stopped
Old Jan 14, 2011 | 09:04 PM
damondarwin's Avatar
Default Inside air fan has stopped
Hi guys my aircon and heater fan does not work. Everthing else on that circut seems ok. It started out it would work when you got going down the road . I though it may have been a bad connection. But i can not find anything. I have not even been able to get the the fan motor. Where is it ? Is this a common problem? Any help b4 i start to remove the dash to find things . Kind Regards Roy
Old Jan 14, 2011 | 09:41 PM
Default Re: Inside air fan has stoped
For starters the fan is in front of the passengers feet.
Look at the Repair manual to be found in the SRT6 sticky section.
Old Jan 14, 2011 | 09:52 PM
Thanks mate but how do i find the manual ? I am not to flash on the computor. I found the fan box removed the bottom cover . It was full of dirt , leaves ect. Have cleaned it . The fan still turns freely.and there is power to one of the wires on the 3 pin plug connector.
Can you tell me where the fan relay is located ? And also where is the aircon filter? Regards Roy
Old Jan 14, 2011 | 09:53 PM
edgehead2000's Avatar
I'll save you some trouble: https://www.crossfireforum.org/forum...where-get.html
And to my knowledge, yes, this is a common problem with our cars. I just hope you and the other guys I helped this week leave me a resistor!
Old Jan 14, 2011 | 09:56 PM
Thanks mate can you tell me where the resistor is located?
I am in Australia mate so the chances of me getting one will be nil.
But if i can find it that would be a start. Kind Regards Roy
Old Jan 14, 2011 | 10:02 PM
No problem. It's the very last post in that thread that holds the answer.
Your Parts Search Returned 1 Part(s)
Just click the link and you'll know what needs to be replaced if you've already taken apart the cabin fan to clean it. Seems simple, unscrew the old one, pop in the new one, and you're done. 15-20 minutes max.
Old Jan 14, 2011 | 11:08 PM
Thanks mate all good . Have found everything, Have removed fan motor and resistor. Will test resistor b4 i order part . Thanks all for your help . It is so easy when you get the correct information. Kind regards Roy
Old Jan 14, 2011 | 11:44 PM
Hi again have found all but the fan relay. Can someone please point me in the corect direction. Regards Roy
Old Jan 15, 2011 | 01:30 AM
Always happy to help our friends on the other side of the planet.
You can find all kinds of manuals and such here;
https://www.crossfireforum.org/forum...tml#post111722
Download to your computer and keep for future reference.
Old Apr 18, 2011 | 05:04 AM
Looks like this is the first quirky problem I've encountered with my 07 Coupe. Washed the car yesterday and right after, when I went for short drive, the blower motor wouldn't run. Consensus is that it's the blower regulator/resistor assembly. Thank's to others, I found several sources on eBay for $55-$65, incl S&H.
Later,
Old Apr 18, 2011 | 09:36 AM
Well, had some time this morning to look at the XFire. Started it up and, low & behold, the HVAC fan worked!!
Then I noticed there was some water standing on the winter mat on the passenger side. So maybe my problem is that darn water drain that is blocked on the passenger side of the cowling. Going to look later this afternoon. Have Momma's chores to work on first!!
Old May 7, 2011 | 11:53 PM
Primeaux's Avatar
I'm going to call the guy suggested in the morning for the $150 part. Everywhere else I've seem to have found is priced around the $300 range.
Old Oct 30, 2011 | 06:55 PM
coolx's Avatar
Smile Re: Inside air fan has stoped
thanx to all you fellas for posting this info - now I know what's goin on with my AC...
Old Oct 30, 2011 | 08:07 PM
robby363's Avatar
If you need the blower motor regulator this is where I bought mine. Great price and works great. eBay - New & used electronics, cars, apparel, collectibles, sporting goods & more at low prices
Old Oct 31, 2011 | 03:05 PM
coolx's Avatar
thank you robby - much appreciated - you just saved me over 50 bucks!
waldig
Sep 2, 2015 11:02 AM
waldig
Jul 30, 2015 07:39 PM
waldig
Jul 29, 2015 06:54 AM
waldig
Jul 15, 2015 02:05 PM
