Can't get windshield clean
I think the first owner of my Crossfire either waxed or put RainX on the windshield because in almost 2 years I have been unable to get a streak free clean windshield. Anyone have any ideas?
Re: Can't get windshield clean
Well body shops use 0000 steel wool to get glass clean.
Originally Posted by srbaker
(Post 835768)
Originally Posted by franc rauscher
(Post 835771)
what year is it?
Try Groit's Window glass Clay...I think that might work...Carl
(Post 835773)
2015.............
Lacquer thinner won't hurt glass, just make sure you stay away from any paint.
(Post 835773)
2015.............
Whoda thunk ? |
(Post 835777)
You hosers up in Canada use the same calendar that we use.
Whoda thunk ? |
(Post 835773)
2015.............
Yeah that helps. Funny too. I can always count on your Canuck humor There is a reason I asked the question. Why don't you wait until I give it and then you can be really sarcastic? |
Quote:
Originally Posted by franc rauscher https://www.crossfireforum.org/forum...s/viewpost.gif what year is it? Originally Posted by onehundred80 https://www.crossfireforum.org/forum...s/viewpost.gif 2015............. FAST and FUNNY . . . Who says you're getting old and slow?? |
Originally Posted by RED DOG
(Post 835820)
Quote:
Originally Posted by franc rauscher https://www.crossfireforum.org/forum...s/viewpost.gif what year is it? Originally Posted by onehundred80 https://www.crossfireforum.org/forum...s/viewpost.gif 2015............. FAST and FUNNY . . . Who says you're getting old and slow?? Some just get hard of hearing. It may not be age related. The year is important because some model years spent time stored on parking lots. Limestone Gravel parking lots put layers of lime dust on the windshields and morning dew turned it to carbonic acid.... etching the glass. Short of polishing compound, there is little that can be done. Strong pressure with cleaning fluids may stress the windscreen glass and cause a stress fracture. It is how mine broke spontaneously the day after I carefully polished the haze. This after a glass guy explained to me how lime dust etches window glass. A little research had previously told me my 2006 model was stored in SC for a year on a gravel lot. |
Use BonAmi cleanser. Then rinse well. works great..
Originally Posted by aschrager
(Post 835835)
Probably would. They still make that stuff? |
Thanks for all your responses, my car is a 2008. I still think it is a coating or wax as it seems to smear when cleaned. I have tried rubbing alcohol, various glass products and vinegar/distilled water combo. It may just require cleaning after cleaning to get it clear.
(Post 835773)
2015.............
:) In this dimension, you are correct. :) . |
I had the same type of thing on my 08 windshield....looked like an overspray of something and just wouldn't come clean. Finally I bought a bug sponge and some Pro Goof Off. I applied a small amount on the sponge and spread on the affected area. I let it sit for about 15 seconds and then I took a straight, one edge utility blade and went over the area. WOW, it came off with ease! I of course then proceeded to apply more "goof off" and cleaned the entire area. Again, I suggest you spray onto the sponge and not directly to keep from getting all over other things. Hope this works for you....let me know.
If you are using micro fiber towels to clean them, stop. They will steak every time.
I consider myself pretty good at this. If I have a smeary, nasty windscreen, I'll try a detergent (Dawn) first. I use cotton terry towels.
Try Clay bar/instant detailer-just like on the paint. Meguiar's Ultimate Compound-this has done wonders for me! As a last resort: solvent. Always be careful. Turpentine removes pine sap, a usual culprit. I've used methanol and even acetone. Like I said: be careful. It WILL muck up a paint job in a heartbeat. |
I say clean your specs or contacts before deciding if the windshield is dirty.:p
| All times are GMT -4. The time now is 06:19 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
