What adhesive to reinsert rubber(?) trim on door sill
Old 12-15-2017, 05:48 PM
CabinIsle1's Avatar
Default What adhesive to reinsert rubber(?) trim on door sill
Rubber(?) / polymer molding came out of track from taper at rear of door opening as it curves upward for 18” above sill. Doesn’t appear an adhesive was used but just pressed into small channel. Tried to press in , but does not stay. Thought about using super glue, but thought I would ask the experts first
Old 12-16-2017, 12:20 AM
JSK's Avatar
JSK
JSK is offline
Default Re: What adhesive to reinsert rubber(?) trim on door sill
3M weatherstrip adhesive. It comes in black.
Old 12-16-2017, 09:33 AM
Are you sure you cannot crimp the channel closed a bit on the weatherstrip and make it hold ?
That's what I do with the weatherstrip when replacing convertible tops.
CharlieO
05-30-2018 11:12 PM
abcabc68
Northeast Forum
07-13-2017 02:04 PM
nickwe21
Detail Shop
07-25-2014 09:32 AM
crookedview
09-27-2011 01:26 AM
CrossfireLTD
08-31-2005 10:10 PM
Quick Reply: What adhesive to reinsert rubber(?) trim on door sill
