Mystery Spring
Re: Mystery Spring
Maybe it has to do with the in and out of the column.
See item #12.
https://www.ebay.ca/itm/CHRYSLER-OEM...UAAOSwgHpa3waq
Re: Mystery Spring
There is a spring on the steering column, There is one for sale on eBay at the moment.
See item #12.
https://www.moparpartswebstore.com/a.../00i78179.html
But I have now checked, and this spring is still intact in my 2004 Crossfire. It is also somewhat larger than the stray tension spring I found. I will keep checking for awhile. Thank you again for your help.
John
Re: Mystery Spring
[QUOTE=John&Terry;912199]Thank you for this information. This spring is a likely candidate, as it is a tension spring also, and located in the same general area as my mystery spring. It is also #20 in this 2004 diagram:
John[/QUOTE
I have finally located the origin of the "Mystery Spring". It is one of two springs which belong to the plastic steering column cover adjacent to the steering wheel. Mercedes Benz Part #1704600395, Chrysler Part #05098991AA. (https://www.moparpartswebstore.com/p...5098991AA.html). These springs keep the small inspection door on the right side of the cover closed. These were really hiding well! Thank you to Marc Matherne for pointing me in the right direction.
Mercedes Benz 170 460 03 95
John[/QUOTE
ReignMan
12-13-2015 07:34 AM
Infinity
07-29-2013 12:12 PM
