Interior Lighting (Dome, Trunk, Glove Compartment)
I'm sure there is some kind of module that controls these, but I don't know what it's called or where it's located. My dome light won't go on and off when I open the doors (switch is to the right). I can push in the button between them and it works, so I know it has power.
What is the module that controls the lighting called, where is it located, and is it easy to get to? |
Re: Interior Lighting (Dome, Trunk, Glove Compartment)
Originally Posted by ROB311952
(Post 915311)
What is the module that controls the lighting called, where is it located, and is it easy to get to? Check for water down beside the foam under the trunk mat with a bit of stiff paper. The pump is a bugger to get to as the trunk panels have to be taken out unless you butcher the foam insert. CLICK for details |
Thanks for the quick reply! Since today was the maiden voyage for Black Beast II and it popped a MAP pressure code like my first SRT-6 used to do from time to time, I erased the code and disconnected the battery for a reset. I will clean the MAF sensor tomorrow and that problem should stay gone for at least 6 months.
Low and behold after that reset, now my dome light goes on when I hit the unlock button on the fob and goes off when I turn the key in the ignition. I'm glad I don't have to mess with that pump thingie! |
I’m having same issue. Once I clean the CLP/SSM, do you have any recommendations on how to seal it to avoid flooding or water damage? |
Originally Posted by Aggy
(Post 917141)
I’m having same issue. Once I clean the CLP/SSM, do you have any recommendations on how to seal it to avoid flooding or water damage? ;) Cannot seal it, it draws in air for the locks (pneumatic). Open up the two rubber grommets under that well area, water will drain out of it when it gets in there. ;) . |
(Post 917141)
I’m having same issue. Once I clean the CLP/SSM, do you have any recommendations on how to seal it to avoid flooding or water damage? Often the pump is beyond repair if it gets wet inside, the terminals get corroded as well. |
