2004 Coupe drivers seatbelt latch
Old Jun 15, 2020 | 03:31 PM
Mauler's Avatar
Default 2004 Coupe drivers seatbelt latch
Trying to replace a broken latch but the seller is asking if it has two connectors or one... I really don't want to pull the whole seat out just yet in case he doesn't have the correct part..
Here is my baby
just got out of storage... little dirty
Old Jun 15, 2020 | 04:56 PM
Default Re: 2004 Coupe drivers seatbelt latch
I am swaping my drivers seat ,,,take a pic and i may have what u r looking for. jim
Old Jun 15, 2020 | 05:00 PM
Mauler's Avatar
Thanks just need to know if the seatbelt latch part has one connector or two. Thanks!
Old Jun 15, 2020 | 05:16 PM
the complete belt
the latch
the center plug looks like two wires,,,pne blue one white
the seat.
Old Jun 15, 2020 | 05:25 PM
Mauler's Avatar
the complete belt
the latch
the seat.
that part with the red button is what I need to know if it's one or two cables... I'm assuming that it is a two connector for that red button latch, thank you for looking and sending images! Thanks
Edit: after looking it looks as if it is one connector with two wires coming from seat latch mechanism..
Old Jun 15, 2020 | 07:56 PM
yes,,,one connector the wires are one blue and one yellow,, the pic with the connectors it is the one in the middle.
Old Jun 15, 2020 | 09:30 PM
Mauler's Avatar
Thanks ordered up the part saves me the headache of having incorrect order...
Old Jul 11, 2020 | 02:58 PM
Mauler's Avatar
Took apart seat and seatbelt mechanism was fairly easy to replace. Two plugs for drivers seat that are connected to a box under the seat. No need to remove whole assembly under the seat. Simply push two small tabs on the sides of the connector box and the cover comes off and you can remove cable ends and seat latch. Done. Now my seatbelt is functional again and now to disable the warning light and buzzer obviously without cutting any wires!
Old Jul 12, 2020 | 04:19 AM
I added aftermarket seat belt extenders, serves 2 purposes : easy to put on and off, and makes the car think it's always attached.
Old Jul 12, 2020 | 02:48 PM
...Now my seatbelt is functional again and now to disable the warning light and buzzer obviously without cutting any wires!
Are you saying you don't like the buzzer going off when in gear without the belt on? There is a way to program that feature out! Search the forum for it.
Old Jul 12, 2020 | 02:49 PM
Mauler's Avatar
Already done bud!
Old Jul 12, 2020 | 02:51 PM
Already done bud!
OK. Curious, did you cut the wires of program it out?
Old Jul 12, 2020 | 02:58 PM
Mauler's Avatar
I just wanted the chime to be off. So I followed the one tutorial that used the key in , on/off sequence to disable chime... I saw the other tutorial that requires cutting, I would never hack up such a thing for that .. I like her to be untouched and prestine!
Old Jul 12, 2020 | 03:06 PM
You and I think alike in this regard... What confused me was you mentioned originally the dash light was also a part of the 'issue'. Glad you have it done and that your on to another challenge! Oh, great pictures BTW!
Old Jul 12, 2020 | 03:12 PM
Mauler's Avatar
Yea it was but after researching I felt the light was necessary and the disabled chime was sufficient. Thanks!
vsilvia
Feb 13, 2017 04:33 PM
2005 Ragtop
Jul 9, 2015 03:16 PM
FUBU
Aug 19, 2012 01:16 AM
Crosstang
May 5, 2004 10:43 PM
sorlando24
Mar 19, 2004 10:47 PM
