Changed valve cover gasket 2x, still leaking oil
Old Mar 4, 2019 | 07:08 AM
furnakit's Avatar
Default Changed valve cover gasket 2x, still leaking oil
Changed valve cover gasket 2x and even used Permatex for a third fix. Still have oil dripping on the passenger side exhaust manifold. I can't see where it is coming from, but it is in the rear. Could it be my head gasket?
Old Mar 4, 2019 | 08:15 AM
Southernscrew's Avatar
Default Re: Changed valve cover gasket 2x, still leaking oil
Valve cover bolts only torque to about 10 INCH Pounds. A head gasket wouldn't leak oil , It would leak water !!
Ken
Old Mar 4, 2019 | 08:54 AM
zip439's Avatar
There are two surfaces to seal on the valve cover gaskets. A smaller cover sits atop the larger valve cover. You must separate the two covers and clean all the surfaces very carefully to insure they are clean and dry before reassembly. The smaller cover attaches to the larger cover only with black silicone without a gasket. The larger cover attaches to the engine with a gasket. Many people only use the gasket to make the seal with the larger cover and have had good results. I placed a very thin coating of #2 Permatex ( non hardening) on the engine before installing the cover with the gasket in place on the cover. I have had no leaks over the past 6 years. I would recommend only using the OEM valve cover gasket. The smaller cover on top the main cover is for attaching the breather hose. Perhaps that hose is cracked or not sealing well. It is not a difficult job, but you must take your time, follow the directions on the black silicone and be certain you have the correct silicone as there are different types of the black available.
Old Mar 4, 2019 | 09:33 AM
NeedsWings's Avatar
Is this happening with Mercedes lower valve cover gaskets or cheaper aftermarket gaskets for you?
Old Mar 4, 2019 | 11:07 AM
furnakit's Avatar
Thanks for the info. Yes I resealed the oil cooler cover on the valve cover, that is looking good.
Old Mar 4, 2019 | 11:08 AM
furnakit's Avatar
Thanks Ken, that is what I was thinking but after 2 gaskets and Permatex, I was thinking out of the box.
Old Mar 10, 2019 | 10:05 AM
DualSportDad's Avatar
how much is it leaking? you could try putting oil dye in and checking from there.
chevy_67_327
Apr 9, 2018 09:12 PM
ri2300
Jul 21, 2010 05:59 PM
beachwalker2009
Dec 1, 2009 09:04 PM
blackcrossfire07
Sep 25, 2009 10:48 PM
jaded1958cars
Feb 22, 2008 01:28 PM
