Need guidance!
Old 07-09-2019, 10:08 AM
Romeroben7's Avatar
Default Need guidance!
I have a 2004 Chrysler Crossfire limited MANUAL
Bought it about a month ago
114,000 Miles
Needwings air intake
flowmaster exhaust
great driver, and I put 1000 miles on it in the first week,
as I was driving I was banging the gears and pushing the pedal to about 90%
and as soon as I hit fourth it bogged out and slowed down until it stopped and finally shut off.
I turn it back on and it starts just fine but now it’s sputtering and puttering something fierce...
I’d say a good 50% loss of power
take it to all the parts stores for a check engine test..
i get
P0171
P0171 confirmed MAF sensor, O2 sensor, pcv, leak unknown
p0221 TPS Faulty
p0174 bank one, bank two running lean
so so I take it to Chrysler, hey these are codes help me out...
thay try charging me 700$ +160 for labor. For ONE O2 sensor......
take matters into my own hands.
Replaced o2 sensors in both bank one and two
took apart THROTTLE BODY cleaned it ,
cleaned MAF sensor with only MAF cleaner
put it all back together.
Still have a lack of power (running at 70% total power is my guess)
Idles a tad rough but not extreme,( I’d say a 3 out of 10 in roughness)
And when I hit the gas there’s no get up and I hear a whistle when I hit about 2700 or 3000 ish, or if I try to press a bit more liberally on the pedal it does it as well .
codes P0171
p0171 confirmed
and P0174 are still present
but I removed the p0221 code
NOTE: Im going through gas exponentially faster as wel..
if if there is any particular direction I can be guided in as to where I should take my next steps I would greatly appreciate it
after that chrysler experience, I have a very rough time taking it to anybody...
Old 07-09-2019, 12:59 PM
Speedy4x4's Avatar
Default Re: Need guidance!
You running good premium gas?
Do you have a vacuum gauge ?
Old 07-09-2019, 01:04 PM
See my sigline!
Romeroben7's Avatar
yeah I dead put some safe cleaners into the tank and some high octane booster to help in the last few fill ups, but, I do no lt have a vacuum gauge
Old 07-09-2019, 02:28 PM
NeedsWings's Avatar
check the valve cover breather hoses, if they are old brittle and cracked it can cause these issues, there are 3 hoses to check.
Old 07-09-2019, 03:35 PM
Romeroben7's Avatar
Are these the hoses that sit above the throttle body and go into them?
Old 07-10-2019, 11:41 AM
NeedsWings's Avatar
yes that is 2 of the 3. the third is the larger hose from the drivers cover to the MAF housing on the back of the engine
Old 07-10-2019, 01:17 PM
Romeroben7's Avatar
All of these hoses look to be in good condition
Old 07-10-2019, 01:50 PM
zip439's Avatar
When you cleaned the throttle body: did you replace the large "o" ring? You seem to have a vacuum leak as Needswings indicated.
Old 07-13-2019, 08:03 AM
Romeroben7's Avatar
Yes
bernard23
04-29-2014 02:24 PM
MizD
07-01-2011 11:51 PM
Whodizking
10-21-2010 11:55 PM
Bryce
05-06-2008 11:01 AM
gsxrat12
04-20-2008 05:16 PM
Quick Reply: Need guidance!
