Questions about colder plugs and detonation
Old Mar 18, 2010 | 09:46 AM
tom2112's Avatar
She can ride with me ;)
Default Questions about colder plugs and detonation
OK, I understand how detonation is the enemy and can do serious harm to your engine, which is why the knock sensor will retard timing to guard against detonation.
So, lots of modders will put colder plugs in their cars to guard against knocking and the retarded timing.
My question is how do you know how many steps colder to go?
I see several folks with SRT-6s have gone two steps colder. Why two? Why not one? Why not three?
The reason I ask is because over in Mini Cooper land, they all seem to recommend one step colder, whereas here in Crossfire land they recommend two. That makes me wonder why.
Old Mar 18, 2010 | 10:05 AM
JHM2K's Avatar
Default Re: Questions about colder plugs and detonation
The timing has feelings too man, you shouldn't call it names.
Do you think it might have something to do with compression ratio? What's the CR of the Mini?
Old Mar 18, 2010 | 10:16 AM
ZAHANMA's Avatar
This absolutely made my day. Hilarious.
On a more pertinent topic, I went one step colder in my plugs and have thought about going another step colder when I change them again (read: soon). I know there is definitely a limit, just because one keeps going colder does not make it better and better.
There are several MBs I have seen that actually suffer from using colder plugs, though they are, from what I've seen, the 63 AMGs.
Old Mar 18, 2010 | 10:42 AM
tom2112's Avatar
LOL, too funny.
The compression ratio is 10.6 to 1 for the Mini Cooper S.
Old Mar 19, 2010 | 12:21 AM
+fireamx's Avatar
LOL, too funny.
My, that little bugger is under a lot of pressure Tom. You should lighten up on it a little.
By the way, when I get my new tires on my Crossfire, you're welcome to test it out. That is, if you're not "manually challenged" when driving a Crossfire.
Old Mar 19, 2010 | 09:50 AM
ZAHANMA's Avatar
Tom,
Who's picture is that in your avatar now? I need to make friends with this person. Haha.
I like the Mini Coopers, they are cute girly cars.
Haha, kidding. They are great cars, like street legal go-karts. Very responsive handling and a little bit of go.
Old Mar 19, 2010 | 10:29 AM
tom2112's Avatar
I dunno who she is, but her pic was in the gallery, so I swiped it.
For whoever put her pic in the gallery: tell her she is invited to do that near my car anytime she wants.
Old Mar 19, 2010 | 12:43 PM
billvp's Avatar
Another question is how often to replace the plugs? I saw on the MBWorld blown engine thread that Tony@Eurocharged said every 3k-6k miles, which everyone else thought ridiculous.
Old Mar 19, 2010 | 01:10 PM
tom2112's Avatar
Sheesh! 3 to 6 thousand miles?!? That's insane. I don't even change my oil that often.
I've had a mechanic of 30 years tell me that in many cars, you should not change the plugs just to change them. If nothing's wrong, don't mess with them, as you're just as likely to install them improperly (incorrect gap, I guess) as you are to help it in anyway. Now, he was referring to non-performance environment, but still that's a big difference between Tony and that mechanic.
Old Mar 19, 2010 | 01:17 PM
ZAHANMA's Avatar
As a bit of clarifications I believe he meant for someone who consistently races their car it is ideal. There is a reason the top fuel guys change plugs after every run.
Old Mar 19, 2010 | 06:08 PM
Xfire fan's Avatar
In a fuel motor the plugs are junk after a pass, the straps are burned off.
Old Mar 19, 2010 | 10:05 PM
RIOT's Avatar
In my Drag boat every week changed plugs and gave them to the fishing boat guys.
Put 22,000 on my car and been through 5 sets and right now eurocharged is installing a fresh set as I type.
Old Mar 26, 2010 | 09:12 PM
tom2112's Avatar
So....
Back on topic:
Does anyone know what the limiting factor to colder plugs is?
How cold is too cold? Where do the trade offs begin and what are they?
Old Mar 26, 2010 | 09:29 PM
tom2112's Avatar
Well, Wikipedia has this to say:
Originally Posted by Wikipedia
If the tip of the spark plug is too hot it can cause pre-ignition leading to detonation/knocking and damage may occur. If it is too cold, electrically conductive deposits may form on the insulator causing a loss of spark energy or the actual shorting-out of the spark current.
Old Mar 26, 2010 | 09:34 PM
tom2112's Avatar
OK, I think I found an answer that will be useful to everyone here. According to NKG's website:
http://www.ngk.com/charglossary.asp?kw=Heat+range
Originally Posted by NKG
An unaltered engine will run within the optimum operating range straight from the manufacturer, but if you make modifications such as a turbo, supercharger, increase compression, timing changes, use of alternate racing fuels, or sustained use of nitrous oxide, these can alter the plug tip temperature and may necessitate a colder plug. A rule of thumb is, one heat range colder per modification or one heat range colder for every 75–100hp you increase. In identical spark plug types, the difference from one full heat range to the next is the ability to remove 70°C to 100°C from the combustion chamber.
Do not make spark plug changes at the same time as another engine modification such as injection, carburation or timing changes as in the event of poor results, it can lead to misleading and inaccurate conclusions (an exception would be when the alternate plugs came as part of a single precalibrated upgrade kit). When making spark plug heat range changes, it is better to err on the side of too cold a plug. The worst thing that can happen from too cold a plug is a fouled spark plug, too hot a spark plug can cause severe engine damage
Old Mar 27, 2010 | 12:48 AM
RIOT's Avatar
Shesh anymore of these threads left...4th website I have had to clean up...
Old Mar 27, 2010 | 02:37 AM
rcompart's Avatar
Originally Posted by RIOT
AAAAAAAAAAAAAAAAHHHHHHHHHHHHHH
beat on ya car....if it don't implode let me know what range plug you were using.............................................
FFFFFFFFFFFFOOOOOOOOOOOORRRRRRRRRRRR
WWWWWWWWWWWWWHHHHHHHHHHHOOOOOOOOOOOMMMMMMMMMMMM
THE BELL TOLLS.................
Got a little Metallica playing in the background do we?
I do second letting us know how it works out. I have a set of Iridium's but I should maybe go 2-steps colder to be sure everything will be alright.
Old Mar 27, 2010 | 09:15 AM
tom2112's Avatar
Doing a little drinking Riot? LOL
Old Mar 29, 2010 | 12:36 PM
RIOT's Avatar
I already run a set colder....sort of cheap insurance...but should I run two sizes colder?
Did have #6 misfire around 128 while beating on a 750i two weeks ago.
Car went into limp mode....pulled off the highway,stopped at the light counted to 10 and prayed and started the car back up and been fine ever since.
Damn I was scared!!
Thinking about trading it in on a clk63 vert amg.
And staying stock! Getting tired of breaking stuff to go fast with the top down!
Old Mar 29, 2010 | 12:54 PM
ZAHANMA's Avatar
Boooo... if you are gonna get a CLK63 you'd better get a BS. Damnit. Then let me take it for a drive .
