Supercharged 6.2 Hemi: “HellCat V8”
1 Attachment(s)
WHOA! Article says it all ...... :cool:
Supercharged 6.2 Hemi: ?HellCat V8? Attachment 31972 |
OoOoOoOoOo I want ;)
Re: Supercharged 6.2 Hemi: “HellCat V8”
Insert that puppy into the Crossy and you'll finally have a true SRT.
Well, at least one that Chrysler can work on & maintain! :rolleyes: The in-tank fuel pump accommodates variable pressures, half-inch fuel lines, and eight injectors, each capable of delivering a flow rate of 600cc/min – enough to drain the fuel tank in around 13 minutes at full power. The large-nosed crank drives a high-flow gerotor oil pump that feeds a lubrication circuit servicing eight high-flow piston cooling jets. A high-capacity oil/air heat exchanger, mounted in the front of the car, mitigates oil temperatures when driving conditions are harshest. The 0W-40 synthetic oil was developed for SRT by Pennzoil. Additional cooling measures include a low-temperature circuit with two air/coolant heat exchangers integrated into the supercharger housing. This setup is designed to keep air temperatures below 140° Fahrenheit (60° Celsius) under extreme ambient conditions, while enabling air flow of up to 30,000 liters per minute. It is effective enough that engine power will not be de-rated due to cooling demands, even after 20 laps of a grueling 3.1-mile road course at an ambient temperature of 100° Fahrenheit. |
I love the dual plug design shared with our engines a 3 valve head would be AWESOME.
I love this quote hahaha ;) "The in-tank fuel pump accommodates variable pressures, half-inch fuel lines, and eight injectors, each capable of delivering a flow rate of 600cc/min – enough to drain the fuel tank in around 13 minutes at full power." |
Just realized that the "over 600 HP" statement gives it power approaching the 640 hp of the SRT Viper's V10. Beastly! ;)
Hole in the headlight for air ftw
So.. This with the 9 speed auto.. Will it fit in a xfire? No chance our 6spd tranwould handle it, right?
