Racing The place to talk about autocrossing, road and drag racing.
Srt-6 1/8 mile
Old Aug 1, 2011 | 12:52 PM
svtcobra's Avatar
Banned
Default Srt-6 1/8 mile
Im kinda dissapointed i took my 6 to the 8th mile last night and could only get a 8.3 out of it my mods are 185 pulley needswings single and let tune. Whats goin on
Old Aug 1, 2011 | 01:14 PM
FUBU's Avatar
Default Re: Srt-6 1/8 mile
Then there are only five factors left:
Tires?
Clock?
Weather?
Altitude?
sorry to say but ... Driver?
Next time you'll nail it!
Old Aug 1, 2011 | 01:22 PM
svtcobra's Avatar
Banned
lol no offence taken but what weired is when my car was stock it was kinda cold outside and i ran a 8.3 the i took it back about 2 months with hotter weather later and stock it ran a best of 8.8 and now i have the mods and i get a 8.3 so maybe its the weather forgot to mention im launching at 1700 rpms
Old Aug 1, 2011 | 02:38 PM
grip grip's Avatar
I can't launch over idle without smoking the tires. You must have some nice Hoosiers on the back.
Old Aug 1, 2011 | 02:45 PM
cjw's Avatar
cjw
What was the temperature? What kind of 60' did you run and what tire, rim size.
I went out with my stock srt with 285/35/18's super sports and cut a bad 2.0 60' and ran a 8.5 in the 1/8th but it was at least 90degrees and very humid.
The other srt ran with a code 3,tune and 275/35/17's a 8.2 1/8th and a 12.5 1/4 mile. the best itsrun is 12.2 on ps2's.
Weather has a lot to do with the times so I would wait till it cools off and beat you best times then
Old Aug 1, 2011 | 04:10 PM
svtcobra's Avatar
Banned
on the back im running the srt6 rim with 285 35 19 goodyear and it was at least between 88 and 90 degrees but also ive heard with the 185 pulley u start running into some heat soak issues so i was thinkin about upgrading to the supercooler and gettin a custom resivor tank to put ice in
bmorgan's Avatar
My best cool weather 1/8 is 7.901. That was at 45° with a DA of 250. I ran a 8.192 with a temp of 81° and a DA of 2489. So, as you can see.... Temp and density altitude can make a big difference in your times. Even with cooler weather, DA can kill your times. On both of these, the 60' was only .040 apart.
Old Aug 1, 2011 | 04:14 PM
bmorgan's Avatar
You need to get some light weight 16" wheels with DR's. I run these with 18lbs. pressure.
Old Aug 1, 2011 | 04:16 PM
grip grip's Avatar
I heard there's a set for sale on here.
Old Aug 1, 2011 | 04:19 PM
bmorgan's Avatar
Haha... I started to mention that, but was too lazy to look up the post. This is the best set up for the Crossfire that anyone has come up with yet.
Old Aug 1, 2011 | 04:36 PM
MikeR's Avatar
The Aero run's the 1/8th in 7.6 to 7.8 and on hot days goes up into the low to mid 8's.... it no likey hot air...
Old Aug 2, 2011 | 04:31 AM
Mimi05SRT6's Avatar
So, so true...Heat is a killer! I went to the track this past Friday and was only able to kook up once without spinning to run a 7.78. When the temps are just right, I'm running 7.5's.
Old Aug 2, 2011 | 09:07 AM
NeedsWings's Avatar
send me a datalog,i will show you the problem in it.
Old Aug 2, 2011 | 09:37 AM
grip grip's Avatar
My guess is no traction on launch for one, but the biggest issue would be high AIT's are causing the timing retard, which is killing power.
Old Aug 3, 2011 | 01:18 PM
svtcobra's Avatar
Banned
I found out my air fuel ratios r in the high 14s low 15s with the 185 pulley should I sell and go with asp 178 or js buy bigger injectors for 500$
Old Aug 3, 2011 | 01:43 PM
grip grip's Avatar
I've got a Eurocharged 181 pulley that will just bolt up to your hub. Swapping should be a 30 minute job. PM me if you're interested. Heck, I might just trade even. Just food for thought.
Old Aug 3, 2011 | 02:40 PM
Holycrap's Avatar
Breakdown of the slip???? yea heat hurts especially if you are modded... with just an intake i didnt have heat soak issues. That 185 pulley might be too much without additional cooling/fuel mods . The car should be well into the 7's with your mods with traction.
Old Aug 3, 2011 | 02:44 PM
Holycrap's Avatar
funny you say that. i couldnt get good 60 foots launching at idle. The best way for me was launch high 1800+ and then ease into the throttle. still crappy 2.0 sixties but otherwise it was 2.1 and up.
Old Aug 3, 2011 | 06:28 PM
blackpepper's Avatar
My roadster ran 8.42 stock after my tune and intake it runs 8.22@86mph with no pulley.I just got some more intake and exhaust work done trying to hit 8.1s without a pulley,I run on 275/40/19 street tires and get good 1.8 60 ft times.
Old Aug 3, 2011 | 08:46 PM
daithi2's Avatar
those are directional, and they are rotating the wrong direction.
