Are the engine management module and relay module the same?
I'm looking to buy a used crossfire from a dealership and it has the check engine light problem. They couldn't figure it out so they sent it to a chrysler dealership to try and do it. I've been reading past articles on this engine light problem and it seems that a module needs to be replaced. Are the two modules listed in the title the same module or two different ones?
Re: Are the engine management module and relay module the same?
He doesn't know, I assumed that was the problem due to the test drive I had with the vehicle. All it said, when I was in it was "Check engine" I didn't see any codes.
Originally Posted by HDDP
The way you access the DTC's is through the OBD port and a scantool... You won't know what is causing the CEL until you read the codes through the scantool... So, until that happens I can't help you...
KDW4Him
18
09-01-2021 05:47 PM
northwest_crossfire
05-30-2016 05:19 PM
BrenLW
08-05-2015 04:53 AM
