Battery Replacement
on
Re: Battery Replacement
Also, FREE installation on most vehicles with battery purchase.
AutoCraft Platinum AGM Battery, Group Size H6, 760 CCA H6-AGM: Advance Auto Parts
I have this one as well - perfect fit, and no issues with the battery living in the northeast.
One of THE best...made by Johnson Controls, the maker of our OEM white Varta batteries and #1 in the world. On sale @ 20% off. Use coupon code CPN1025715 at your local store , or use code J53E online to order and pick up at store in 30 minutes!
on
Stay away from the Diehard AGM group 48 also. According to Consumer Reports.....
One of our evaluations, called a "life test," involves repeatedly draining and recharging batteries while they are immersed in 167-degree water—a protocol based on an industry test. This simulates the taxing cycles batteries go through while subjected to high underhood temperatures. We extended the test from 10 to 15 weeks last year, to more accurately reflect battery life over a longer period.
Two samples of the DieHard Advanced Gold 50748 in Group 48 failed this test after just six and seven weeks—not even halfway through our stringent test regimen. Two more examples purchased for retesting also failed.
The failures are especially noteworthy because the DieHard Advanced Gold is an AGM (absorbed glass mat) design, which typically makes for a more rugged and longer-lasting battery than a conventional battery. Our test samples of the DieHard Advanced Gold 50748 were the only AGM batteries that did not to survive on average 13 weeks or more of the life test, and they would not have lasted even through the old 10-week test. All other AGM batteries in this test scored much better in the life test.
Since cars now are coming with 2 batteries due to all the electronics. I think the best bet is to get the battery with the highest CCA and CA for our cars due to the finicky sensors and electronics..
That being said I am going to go with the Optima Red Top 34R. What is the "spacer" that people are needing with it for it to fit properly? Any pictures?
Thanks
Thanks
KDW4Him
18
09-01-2021 05:47 PM
northwest_crossfire
05-30-2016 05:19 PM
oldvintagedude
08-14-2015 06:20 AM
BrenLW
08-05-2015 04:53 AM
