Steering box adjustment?
Old 11-01-2013, 11:24 PM
MB Star's Avatar
Default Steering box adjustment?
Is there any adjustment in the steering box? Some steering boxes have a screw with a lock nut that allows you to take up any play in the gears, is there anything like that sort of adjustment?
Old 11-02-2013, 12:18 AM
arejohn's Avatar
Default Re: Steering box adjustment?
Yes there is. Never saw a post from anyone adjusting it though. Looseness in steering typically attributed to stabilizer.
How many miles that you are asking?
Old 11-02-2013, 09:12 PM
MB Star's Avatar
84k on the car
Old 09-22-2017, 05:12 PM
I would like to adjust mine also. I am thinking of cutting a hole in the heat shield to get to the adjustment screw/nut. I would need to repair that after. Hadn't thought it all the way thru yet.
Old 09-22-2017, 06:26 PM
Manual doesn't show picture of the adjustment screw and nut :
The following 2 users liked this post by ala_xfire:
Dunewalker (06-13-2023), Nynick8 (09-23-2022)
Old 09-22-2017, 06:30 PM
Steve Jr's Avatar
Have you replaced the steering stabilizer (dampener) yet? There is a noticeable in difference in response, when you do. Especially if its higher mileage car.
Old 09-22-2017, 08:00 PM
Yep it's new. And I made sure the pinch clamps are tight. I am going to put on new shocks. The looseness in the steering is more pronounced when off center. I have adjusted steering gears before to fix the problem in other cars. This one is just so hard to get to.
Old 09-22-2017, 08:06 PM
The adjusting screw and jam nut are on top the box just under the heat shield. I may try and fashion a wrench that can loosen the jam nut from below and make a small hole in the heat shield got the hex wrench. That is if all the planet's align and Orion decides walk across the sky.
Old 12-23-2019, 08:12 PM
hi, did You do this adjustment in Your car?
I tried to take off the exhaust but 2 bolts couldn't even reach with the key. So is there any other way to make this adjustment?
Thanks in advance for replay.
2005 Ragtop
10-03-2015 03:01 PM
Mackel
09-29-2015 02:41 PM
toob
09-26-2015 11:44 AM
cdcrone123
09-20-2015 10:02 PM
bbsrt6
09-19-2015 11:21 AM
Quick Reply: Steering box adjustment?
