Very Loud Continuous Beep
Re: Very Loud Continuous Beep
Hi John,
normaly there should be a engine check light in combination with the very loud beep sound. Does the engine check light work when you put ignition ON?
Oil pressure has nothing to do with oil level. Oil pressure is very important for the engine. More important than the right oil level. Take a look in the workshop manual and serach for oil pressure.
Because it's an SRT6 and the alarm sound comes up when you kick down: when was the compressor oil changed last time?
Regards
Markus
Regards
Markus
Hi John,
Regards
Markus
Regards
Markus
sorry alarm does not sound when i kick down but after moderate driving to hard
turn ignition off alarm stops
continue driving for a few minutes before it kicks in again
john
There are parking sensors front and rear but this beep is louder
You say it's louder than the parking sensors, but have you tested them at a near-impact distance? Try having a mate walk very close to them and see if it makes the same noise.
If you've fitted any accessories which are causing RFI or if a sensor is loose, it could be "detecting" collision.
Give it a go and share your results.
I do think you are correct I tried it pulling very close to the wall so instead of getting an intermittent bleep I made it go constant and because I have only recently got the car and only really heard the reversing parking sensors omit there bleep from the rear.
When the front goes off as a contastant bleep it is as loud and the same sound
will be getting the garage to look for me thanks all
To me it sounds like the reverse sensor system is screwing up. The double beep when you first turn the key on, is that a normal thing on your car? It definitely is not a factory installed beeping emitter that is making that noise. Try disabling the reverse sensor system and see if the noise goes away.
NO its the front parking sensor alarm. You dont get to hear it go continuous unless you get that close you hit something!
My garage has puled the plug on it for a quick kill
it was located just behind the front vent
just for info, the rear still work as there independent of the front
regards john
regards john
Yes the parking sensor KITS look aftermarket and this car is running 2 seperate kits
1 fir the front ( presently disabled ) and 1 for the front.
I stand corrected on the RHD Roadsters I dont know why I thought that
many thanks
Please help
just drove the car and got a loud continuous beep, so stopped the car, turned off ignition and re started noise came back after a few minutes driving
Not like lights noise/beep as thats intermittent and no where near as loud as this alam/beep
It is Louder than the parking sensors and like I say it is just a continours high pitch noise no warning lights on dash???
HELP?
HELP?
on
