Any tips for winter storage?
on
Re: Any tips for winter storage?
sshistand - I too, live in Northern Kentucky. My Crossfire is my first and I'm wondering about winter storage/parking. I am in a condo with no garage, so I will just have to put a car cover on mine. I think I will put some fuel stabilizer in mine and drive it a bit to make sure it mix's well. My concern is the battery. I will not use a tender because of the concern for fire. I'm also afraid to disconnect the battery for fear of messing up the electronics. Someone stated here that if you disconnect the battery, DON'T disconnect the negative first. I've always disconnected the negative ground first. Maybe the best bet would be to try and drive the car for about an hour every three to four weeks. Hopefully the battery would not discharge in that length of time. I would welcome any and all information on this storage issue. Onehundred80 suggested searching "storage" but, who do you believe? If anybody has any ideas please post them here, or better yet, can you email me at jpmlholian@aol.com.
Thanks Gentlemen
Jim
Thanks Gentlemen
Jim
on
Correct but that is not what you said in your post #14 in this thread some years back. I think you made a correction in that post but what you say is still wrong.
............ I would welcome any and all information on this storage issue. Onehundred80 suggested searching "storage" but, who do you believe? If anybody has any ideas please post them here, or better yet, can you email me at jpmlholian@aol.com.
Thanks Gentlemen
Jim
Thanks Gentlemen
Jim
I disconnected my battery to work on the car some months ago, I put a charger on it once since then. I have to have a Drive Clean test before I can renew the plate sticker and all the pollution parameters will have to be reset by driving it around before it is tested. I’ll have to get a temporary sticker, some cops cars have a camera that runs license plate numbers automatically as the cop drives around. My son got a ticket for an expired sticker that way, it was just a day or so late, correct month but date wise it was expired.
No harm if the wrench touches the frame from the negative terminal before it is loose,
can't say the same for a bridge from the positive terminal to the frame.
Possible exploded battery or severe burns from the hot wrench
Good to hear there is another Crossfire so close. I would not leave your Crossfire sit without running for more than a month. I keep my SRT covered in a Barn. Start it even in winter once a month and never start it without running 10 miles at least to dry out the exhaust. I also believe these cars are electrically sensitive and need to be with a battery charged to avoid problems. I run about 2,000 mi a year on mine and love it. Hope to meet you in the near further.
on
As far as I know, the reason for removing the negative cable first is the wrench.
That is one of the main reasons for removing the NEG cable first (reverse if you have a POS ground vehicle, if there are any on the road anymore). It becomes a necessity on our XF's due to the alarm system because the alarm will sound if the POS is removed first.
I put the dodge challenger in the garage, add a battery float charger and wait for spring. There are no tire issues, and a full tank of fuel to avoid condensation, ready to go.
Iam really amazed that people believe that it need be climate controlled, its a car, not wine !
The 73 dodge does not require babying and the crossfire does not get anything special either.
Happy New Year, Woody Enjoy
Who would you believe if a couple of people answered this request of yours?
I never knew you could do that, thanks.
