how do you completely disable traction control?
Old 02-03-2018, 02:19 AM
wcschuyler's Avatar
Default how do you completely disable traction control?
on a mission to find a way to completely disable the traction control on my 04 n/a, ive read other threads that said to remove I think the 17&18 fuses but those are non existent on 04 models as far as I know(at least on mine), someone else said its on the bcm under the shifter. id like to wire a switch to it so I can turn it on and off, so does anyone have any insight into this which fuse or wire/plug I need to access to completely turn off the traction control? does anyone know where I can find a schematic for the bcm? thanks.
Old 02-04-2018, 12:45 PM
NeedsWings's Avatar
Default Re: how do you completely disable traction control?
if you are trying to drift the car you will want to unplug the yaw sensor
Old 02-04-2018, 07:49 PM
waldig's Avatar
Talking Re: how do you completely disable traction control?
My yaw sensor is connected to a switch for that purpose, its located rearward of the shifter under the carpet. Woody
Old 02-05-2018, 06:02 AM
wcschuyler's Avatar
ooh nice any pics or something I can go off of would be greatly appreciated!
Old 02-05-2018, 04:54 PM
alexdc's Avatar
will tc still kick in?
Old 02-05-2018, 05:29 PM
NeedsWings's Avatar
hahaha...... no
Old 02-07-2018, 02:40 AM
alexdc's Avatar
hahaha...... no
ABS will still work?
Old 02-10-2018, 02:32 AM
alexdc's Avatar
Now I'm confused. I thought there was no way to totally disable traction control/stability control without pulling a fuse and disabling both + abs.
Can someone clarify? I definitely want to disable tc/stability but keep abs. Not on the streets.
Old 02-19-2018, 04:17 AM
wcschuyler's Avatar
Theres no fuses on my crossfire
Old 02-19-2018, 03:55 PM
Veerry interesting!!!
Old 02-19-2018, 05:31 PM
Wonder how that one made it off the line and through QC ?
Old 02-20-2018, 01:38 AM
alexdc's Avatar
Nobody is aware of this?
Old 02-20-2018, 03:52 PM
JEFASOLD's Avatar
I have lots of 'em, I'll loan you a few!!!!
Old 02-23-2018, 04:16 AM
wcschuyler's Avatar
the mentioned fuses related to the TC...
Old 04-03-2018, 06:35 PM
alexdc's Avatar
So the yaw sensor in the steering wheel needs to be unplugged?
Can we get more info on this. I wonder if we could make a module to fool the system.
Old 04-03-2018, 08:19 PM
The yaw sensor is NOT in the steering wheel, it is under the center console.
Old 04-04-2018, 12:32 AM
alexdc's Avatar
But will unplugging the sensor let you spin the tires as much as you want? with tc off?
will any light come up on the dash?
Old 04-04-2018, 04:43 AM
No personal experience, but others may know.
The ABS communicates with it via CANBUS and there are a dozen or so P codes listed,
so I imagine at least a CEL light and probably ABS too.
Old 04-10-2018, 12:31 PM
No idea how this particular car is set up but usually the ABS and TCS are using exactly the same sensors and same computer so disabling TCS by pulling a fuse will probably also kill ABS.
Old 04-11-2018, 02:04 PM
waldig's Avatar
I have a switch on the yaw, when it is on the abs light is turned on, why do you want spin your tires?
I had a phantom grip and later went with the wavetrac (sp) for traction!
Woody
Quick Reply: how do you completely disable traction control?
