Switched Power for VDO
OK, got the underpanel out, gages wired and will start with oil temp. I have one power wire for the two gauges, where is a good place to get switched power? Will run the sending unit wires (2) out to the engine through a port on the left side fuse box.
Found a bunch of broken tabs where the P.O. had put in some stereo, mine now has the stock one in, he must of kept the other, did a s**t job under the dash!
Thanks
Dan
Thanks
Dan
mrphotoman
11-21-2008 05:06 AM
