Strange things after new SKREEM install
Hi Guys,
Spent a few weeks reading and picking everyone's brains here and you all have been a huge help getting my crossfire back on the road. About 1 month ago it just stopped running and I did lots of researching and it was the Skreem unit so I ordered one from Rob at NeedsWings. He was awesome, ..Sent it quickly and after watching install video my car fired right up. Thank you all so much for that.
Now the weird thing. My ABS light is now on after never being on before as is my BAS-ESP light and also the light with a exclamation point. Took me a while to figure out the lights not working are my brake lights...UGH
After reading the forum I figured OK, let me throw in a new battery and make sure that is NOT the issue and it changed nothing. I'm not sure where to look next or if anyone else had similar issues after replacing their SKREEM?
Any help would be super appreciated!
Troy
Troy
Re: Strange things after new SKREEM install
Hi Guys,
Troy
Troy
Hsve you tried reading the fault codes?Sometimes there is a fault without the CEL going on.
I haven't tried reading the fault codes yet...Maybe I can pick up a cheap scanner at Harbor Freight. Was hoping to get some ideas before spending more money. How can 3 lights be on and all these things fail right after installing the SKREEM. Could I have hit something or done something during the replacement?
Troy
Troy
on
Start the car, drive to some grass or sand (pavement is too tough on the steering).
Park the car, crank steering wheel all the way to the left, then all the way to the right then all the way back to the left.
Drive car a short distance. Park car. Turn engine off.
Restart car, drive home.
See if that clears at least one light. And as Dave said, if the ECM sees contradictory input from the wheel speed sensors, it will light the light telling you that ABS is compromised because it can't determine all of the wheel speeds.
on
WAIIIIIIIIIIIIIIIIIIT a minute. Your "lights out" light is on, the brake lights dont work and your ABS is on?
Your brake light switch may be bad. It is not hard to just order one and replace it. This assumes that ALL brake lights are not working, if only one is out, then the 'lights out' light is real and the ABS light is probably on due to a bad wheel speed sensor or the steering thingy is not calibrated. I covered the calibration in the last post.
on
Thanks, Dave.
And here is Dave's answer to your question:
https://www.crossfireforum.org/forum...-location.html
OK..Found a new part at autozone so just installed it. This is where it gets weird.Que the twilight music!
I re-hook the battery and start the car. The ABS light and BAS-ESP lights are still on HOWEVER...The dummy light with exclamation point is off so I figure, thats a good start. At least I have my brake lights back...NOPE!
The light went off but still no brake lights. WTF
On top of that I couldnt even get it in gear until I kept playing with either the gearshift or brake pedal and then doink...It started working but makes this clicking sound now that it didnt before. Its not like it was hard to put in and I pressed the plunger before putting it in and it didnt make a licking noise...UGH
So my dummy light is gone but still no brake lights. Very frustrated!
Troy
Troy
on
The fact that you have no brake lights AND you can't get it out of gear tells me the switch/brake light circuit is still not right.
Is the new part REALLY the right part? Buying electrical system parts at Autozone for these cars is a dubious endevour.
There are these places like Germanautosupply.com and FCPEuro and Needwings.com that most of us go to.
Hey Pizzaguy...I wasn't able to get out of gear at first. After pressing the pedal a few times I am now able to drive it but still no brake lights. Could I have gotten a bad one?
Does it matter which side of the plug I use?...There are (2) 3 prong inputs but only (1) 3 prong plug.
Troy
Troy
on
2) Yes. But I've not had to change one so Im not much help, best I can say is that the new one should be plugged in as to duplicate the old one; again, IF you get the right part.
Hi pizzaguy,
The part is identical in every way. My old one had two plugs as well...Idiot me didn't notice which side of the plug i used but I will try the other side later tonight when I get home. I ordered another from RockAuto just in case it is bad!...They are cheap so I'm OK trying another just to make sure its not this before I move on to whatever may be next which at this point, is another trip to a garage?
I havent heard any other ideas so garage might be my best bet. At least its runs now..LOL
thank you for all your help!
Troy
Troy
Hey Pizzaguy,
I overnight-ed a new part from RockAuto and installed it today. Nothing has changed other then the same thing as the last new part. The dummy light has gone off yet I still have no brake lights, no 3rd brake light either and the ABS and BAS-ESP light are still on. Any new ideas or am I screwed?
I think I checked every fuse on the car at his point!
Im sorry to say this car is losing its luster...really fast!..I attached a picture of the car in case anyone wanted to see the culprit. It has been well cared for with really low miles which is why this pisses me off even more!
Troy
Troy
