Water pump gasket advise please.
So I have the water pump off of my car. I have a new GMB water pump that came with gaskets. I guess I didn't look at them close enough before I started because I thought it was a flat material type gasket which is what the oem pump had on it that I removed. The new GMB pump has a metal frame and a rubber seal. Is this a good seal to use? Ive obviously never replaced a water pump before but I've never used a gasket like this before either. Is this a new and better type?
Re: Water pump gasket advise please.
Ok never mind folks. I see whats going on now. I just realized that my original gasket is also a metal gasket. So I should only need my new metal gasket as well. The groove in the new metal gasket threw me off. It will flatten out just like the oem one I took off once installed. Crisis averted!
I finally figured out my mistake. SOME of these cars used a rubber gasket set into a groove. Others used a metal gasket that you need to put sealant on both sides and assemble. The metal gasket has a groove in it but once bolted down that groove will provide the seal as it flattens out. They provided both type gaskets. I only needed one. I did not have a groove built into the pump mounting surface so I needed the metal gasket. I saw a couple videos of others changing a water pump on a Mercedes and they had the groove for the rubber gasket. Interesting since these are Mercedes motors. I'm all assembled now. Just need to fill it up with coolant and hope I don't have any leaks. Fingers and legs crossed!
ONE MORE QUESTION........I drained the system today at the radiator petcock. I got about 7-1/2 quarts out. Do I need to worry about the coolant that in still in the engine block? The coolant I drained is blue but I'm putting Zerex G-05 back in. System holds 11.8 quarts...just short of 3 gallon so there may still be about 4-1/2 quarts still in there?
The instructions that came with the pump said to apply sealant on both sides of the metal gasket...which I did. Guess I didn't mention that.
on
I have never installed the water pump type you are replacing but the gasket attached to the metal frame will work perfectly. The original single bead gasket was more than likely installed automatically with a robotic type manipulator at the factory. The one in your photo on the right has a bead of sealant precisely positioned relative to the pump's mounting hole pattern. This type of seal is probably a silicon or butyl elastomer and does not need any additional sealant. Install it dry. It would almost be impossible to precisely install a frameless gasket on the left.
