running lights on when brake pedal pressed
2004 limited coupe. Whenever the brake pedal is pressed my front running lights(led) turn on. When the running lights are turned on by switching them on the brake lights turn on. I've gone through grounds and cleaned them up, issue still persists. any ideas? thanks.
Re: running lights on when brake pedal pressed
Originally Posted by droopaloop
(Post 917657)
yup, that was it. took out the bulb and put it back in and it went away. Thanks!
(Post 917796)
That’s what I recall. |
(Post 917846)
I think some bulbs will fit 180 degrees out of the correct position and the bulb terminals short circuit the other bulb circiuit. That’s what I recall. |
(Post 917857)
I recall that what you recall is what I recall.
