Whistle sound from under the glove box...Please help
Old Aug 7, 2007 | 12:23 PM
Maxx Power's Avatar
Default Whistle sound from under the glove box...Please help
All,
I have an 04' coupe that I recently purchased. I have had this strange high pitch whistle noise from right under the passenger side glove box. This only occurs when I turn on the AC and immediately after I turn it off. Does anyone know what assembly is under the glove box? Or what might be causing this? It appears there might be a filter of sorts that is not sealed that might be causing the high pitch sound.
Please help.
Maxx
Old Aug 7, 2007 | 01:35 PM
spensley's Avatar
Default Re: Whistle sound from under the glove box...Please help
Under the glove box there is the cabin air filter.
Check that out - do a search on replacing cabin air filter.
It's your lucky day...
https://www.crossfireforum.org/forum...bin+air+filter
Old Aug 7, 2007 | 01:51 PM
Maxx Power's Avatar
Thank you...looks like this will be an easy fix...appreciate the timely response.
Old May 30, 2008 | 02:21 AM
crossbow's Avatar
hey
i'm new to this form and i would like to tell you that i have a whistle like sound from my glove compartment also. it just started at 36800 miles. at first it was like a cell phone bippp and then would be louder and the would stay on for a sec or two. please let me know if your car stoped whistleing because it drives me crazy.
crossbow
Old Jul 24, 2013 | 11:12 AM
oconnelg's Avatar
I have on 07 model and the same noise just started but has increased in the last few days.Any remedies?
Old Jul 25, 2013 | 02:14 AM
itsky's Avatar
Check out the cabin air filter for starters. That's the easiest (and cheapest) replacement. It could be the blower motor as well.
Old Jul 25, 2013 | 10:47 AM
oconnelg's Avatar
Thanks will do. It does stop when I click the cold air button off with the A/C on....
Old Jul 25, 2013 | 12:25 PM
It's probably the vacuum for the heating/AC module under the dash, I cannot find the article in which I added the links to previous posts on this.
Old Jul 29, 2013 | 11:05 AM
oconnelg's Avatar
Where is this located under the dash? I did change the air filter in the cabin as some recommended but the noise persists. Is this easily reached?
Thank you
Old Jul 29, 2013 | 11:26 PM
boostmonkey's Avatar
Whistle tip? "Da whistles go WOO-WOOOOH"
Old Jul 29, 2013 | 11:34 PM
Thank you
If you look at the photo I posted you can see a carpet, you already have the other clue - it is coming from the glove box area. Put the two clues together and ............... elementary Watson.
TerryR
Dec 13, 2019 03:27 PM
Mackel
Oct 16, 2015 09:03 AM
brandoni
Sep 30, 2015 07:48 PM
toob
Sep 26, 2015 11:44 AM
BEATv1
Sep 10, 2015 12:58 PM
