Delay wing deployment to 75 mph
Old Nov 10, 2008 | 08:21 AM
Kit Fox's Avatar
Default Re: Delay wing deployment to 75 mph
Originally Posted by Maxwell
...reduce wear and tear on the linkage and electric motor.
Is that a problem?
Old Nov 11, 2008 | 08:22 AM
+fireamx's Avatar
Originally Posted by Kit Fox
Is that a problem?
I don't think it's an actual problem K.F., because I haven't read where anybody has actualy worn out the motor on their wing.
But by shutting it off, (like Maxwell pointed out) it would cut down on wear and tear.
I personally feel the main reason for the wing coming up before 65 mph is because here in the USA, if it came up at the speeds where it actually is needed, nobody would ever get the chance to see it.
Old Nov 11, 2008 | 08:54 AM
maxcichon's Avatar
I disagree! I would!
Old Nov 11, 2008 | 09:02 AM
+fireamx's Avatar
Well I should have said "MOST" drivers in the USA would never get to see it.
I wasn't taking into consideration the "crazy" ones Max.
Sorry I didn't get a chance to have talked to ya at the Dragon, you always seemed to have alot of people around you everytime I came up, and I didn't see anybody passsing out numbers.
By the way, your car looked great!
Old Nov 11, 2008 | 09:22 AM
corfire's Avatar
Maxwell, just tap into the fuse box on the drivers side and "hot wire" the wing fuse with a "on-off" switch and you can shut the wing down until you hit the switch, at what ever speed you want it to go up.
Just be sure to put an in-line fuse to take the place of the original fuse that you pulled.
This part of the quote is very important. If you remove the original fuse and don't install one in line with the switch, a shorted circuit could cause damage in the form of burnt wires or even a fire. Fuses are there for a reason.
Old Nov 11, 2008 | 09:37 AM
maxcichon's Avatar
I was figuring I had pi$$ed you off along with everyone else! Sorry I didn't spend some time with you either. C'mon down in the spring and we'll catch up?
Thanks for the kudos.
Old Nov 11, 2008 | 09:50 AM
+fireamx's Avatar
Oh I forgot to add, be sure to use a "waterproof" in-line fuse if you place it under the hood like I did.
My original one quit working due to just a little corrosion, and I had to replace it, just a couple of weeks ago.
Old Nov 12, 2008 | 10:20 AM
Isellthem's Avatar
Maxwell, I for one would be very interested to see how your timer delay do-hickey works out. Just this morning on my way to work my spoiler came up in a 45mph zone. I really think this caught the local authorities eye. Thankfully they didn't pull me over, but I did get an escort to the town line. I would like to copy any mod that successfully delays the spoiler deployment without any input from me and without tripping the alarm. Keep us informed with all the details, thanks.
Old Nov 13, 2008 | 07:54 AM
RIOT's Avatar
Try asking one of the tuning companies like LET for instance if they can change the speed it deploys at.
They were able to lower the temp at which my fan turns on...maybe they can do that also?
From the little I know they can change any setting....
My .02
Old Nov 14, 2008 | 09:47 AM
Christopher12284's Avatar
I wasn't sure if this post should go here, or if I should have made a new topic for it.
Anyway, I did some quick calculations last night, and figured out the following.
Downforce generated by extended rear spoiler @ diffrent speeds
10mph = 5lbs.
20mph = 10lbs.
30mph = 15lbs.
40mph = 20lbs.
50mph = 25lbs.
60mph = 30lbs.
70mph = 35lbs.
80mph = 40lbs.
90mph = 45lbs.
100mph = 50lbs.
110mph = 55lbs.
120mph = 60lbs.
130mph = 65lbs.
140mph = 70lbs.
150mph = 75lbs.
160mph = 80lbs.
170mph = 90lbs.
180mph = 100lbs.
Also, if I'm wrong on my calculations, which I very well could be, since math never was one of my strong points, feel free to repost the table, with correct numbers..
Old Nov 14, 2008 | 03:08 PM
Tazz's Avatar
Don't know about your math and the downforce, but there is one other component to this : I know from my time with Audi that the minimal downforce of the spoiler added to the TT did not tell the whole story, it was also the removal of the lift generated by the body shape without the spoiler.
syfi
Mar 28, 2026 04:14 PM
jimf
Oct 10, 2015 10:22 AM
grip grip
Other Cars Etc
Sep 26, 2015 09:52 PM
grip grip
Other Cars Etc
19
Sep 19, 2015 08:43 PM
Idrenak
Sep 19, 2015 08:17 PM
