Going with NOS...
Old Aug 8, 2008 | 02:13 PM
DesertFox's Avatar
Default Re: Going with NOS...
It was a tad bit annoying when the auto version of my previous car would consistently put down better times than my stick-shift car, stock-for-stock. That showed just how much the gearing matters and how little the type of tranny does. Not to mention the consistent brake launch of an auto.
Old Aug 8, 2008 | 04:46 PM
Duncan's Avatar
Don't underestimate the power of the busa......Its scary fast anywhere straight liine or curves
Old Aug 9, 2008 | 07:22 PM
stryfox's Avatar
Default Re: Going with NOS........
Originally Posted by psuperti
I take corners on nitrous and have my kit for over 2 years. Don't stress about it. If you run into problems it will be a good excuse to buy an srt6 engine .
Got any ET times on the bottle?
Old Aug 9, 2008 | 07:30 PM
Originally Posted by DesertFox
+1. If you're gonna run nitrous, you better run one of these window switches at a bare minimum. The only thing I would verify is whether traction control will reduce the TPS signal that you're tapping into (I think it should, but double-check).
I have one of these also brand new window sw 3000 on 6000 offnever installed will sell for 100, + 10 ship ans a complete NOS system USED local pick up only ( beacuse the tank is full I want 425. for this system nozzles i have with it is 35, 50 , 75, 100.
Old Aug 14, 2008 | 06:04 PM
BlueStorm's Avatar
so did you go with the tvt250 kit? much better power across the rpm power band then N2O.
BobaFettm
Racing
Sep 17, 2004 02:50 AM
BobaFettm
Apr 27, 2004 05:02 PM
