Headlamp Freaking Switch!
Old Aug 20, 2010 | 10:36 AM
mophreakous's Avatar
Default Re: Headlamp Freaking Switch!
Well the signal lights work, didn't know about replacing that switch 2 thought(Grrrrr) Checked all fuses and everything is good. I got a 30 day guarantee with the one on EBAY but this switch is better than the one I had in although not fixed so I guess I will keep(only 50 bucks). Hopefully a new one will work. I took the bottom panel off just to have more room, don't think you will be able to slide it out from the side. Take out the air vent on the switch itself, there are 3 screws behind that along with one inside the fuse panel itself. Not hard just time consuming cause of the small space to work....... Good Luck
Osusannah
Feb 12, 2024 01:49 PM
fastfred
Nov 5, 2018 09:47 AM
Reliableron
Oct 17, 2015 10:19 PM
o55ie18
Oct 5, 2015 05:50 PM
Big_Country
Sep 22, 2015 03:47 PM
