CrossfireForum - The Chrysler Crossfire and SRT6 Resource (https://www.crossfireforum.org/forum/)
-   Troubleshooting & Technical Questions & Modifications (https://www.crossfireforum.org/forum/troubleshooting-technical-questions-modifications/)
-   -   Auto Dimming Mirror - it's not just for '04s anymore! (https://www.crossfireforum.org/forum/troubleshooting-technical-questions-modifications/46448-auto-dimming-mirror-its-not-just-04s-anymore.html)
OKC-XFR Nov 11, 2010 11:18 PM
Ever since I found out that '04 was the only year that came with an auto-dimming rear view mirror, I've thought how unfair that was and that I wanted one! So I found one on eBay and set out to make it work.
The first step was to remove the dome light assembly - a simple task. Just use a flat plastic tool to pry out the cover:
https://www.crossfireforum.org/galle...dium/00140.JPG
And pull out the 2 screws holding in the assembly:
https://www.crossfireforum.org/galle...dium/00336.JPG
Which leaves you a large hole that gives you access to the universal garage door opener wiring:
https://www.crossfireforum.org/galle...dium/00531.JPG
I originally took out the garage door opener because I had heard that all the wiring for the auto-dimming mirror was already in the '05 and up models, and I was looking for a connector somewhere to plug the mirror into...no such luck. The only wiring in the headliner is for the garage door opener.
The next step is to remove the old mirror. The manual says to use a 5mm metal rod, but I used a 3/16" allen wrench that fit very well. You insert the wrench into the hole in the base and rotate the base 90 degrees:
https://www.crossfireforum.org/galle...dium/00925.JPG
This is what it looks like off the window:
https://www.crossfireforum.org/galle...dium/01018.JPG
A small round bracket stays on the glass and luckily it is the same part for both mirror styles.
https://www.crossfireforum.org/galle...dium/01122.JPG
Now to put the new mirror on - you have to thread the wire assembly under the edge of the headliner through to the hole that the dome light assembly mounts into. The mirror goes on the glass the reverse of how the old one came off. This was the hardest part of the job - the casting of the mirror base is slightly different between the auto-dimming and regular mirrors. It's hard to describe how to put the mirror back on...you have to line up the mirror base on the bracket, then keep pushing on the mirror base towards the headliner as you rotate it to lock it in place. It took me 4 tries to get it to lock in properly - you can tell when you get it right because the base is very solid against the glass.
Now that the new mirror is attached, it's time for the wiring. The auto-dimming mirror just uses 3 wires: power, ground and a signal from the reverse lights. '05s and up have switched power and ground, but no reverse signal. The reverse signal is used to turn off the auto-dimming feature when you put the car into reverse to help you see better when backing up at night. So what I did was connect the switched power and ground, and put in a small switch on the power line to turn off the mirror manually if necessary. Here is a wiring diagram:
https://www.crossfireforum.org/galle...ror_Wiring.JPG
And a pic of how I wired in the new mirror:
https://www.crossfireforum.org/galle...dium/01316.JPG
Luckily, the place I got the mirror from (eBay seller) sent me both ends of the connector, so I was able to wire in the mirror and still be able to unplug it if necessary.
Put everything back together and VOILA! To test it, turn the key to ON and cover up the light sensor on the back of the mirror (the non-mirror side) - this should make it go dark.
https://www.crossfireforum.org/galle...dium/01414.JPG
It is amazing how much nicer it makes driving at night! It was definately worth it. :cool:
joejet Nov 12, 2010 12:00 AM
Re: Auto Dimming Mirror - it's not just for '04s anymore!
Very cool Jon. I"ll start looking.
Sheldon Nov 12, 2010 11:28 AM
Nice write up, really too bad about the reverse signal, would have made installing a backup cam mirror very easy :)
Valk Nov 12, 2010 10:37 PM
Good write up...I have made this thread a "sticky"
Larry Hitze Nov 13, 2010 12:18 PM
OKC-XFR, I copied this to my computer and saved it if that is ok,even though I have it already it is a great write up for repairs if needed. Larry
OKC-XFR Nov 13, 2010 09:16 PM
You're welcome to it, Larry - that's what we're here for isn't it? :D I'm happy that I could be of help.
smfrycruzr Nov 15, 2010 07:38 AM
Jon, you know there is going to be a run on these, better find them quick.:p
amx1397 Nov 15, 2010 08:44 AM
great wrght up thank you ,,it needs to be put in HOW TO (Technical & Modifications) section so everyone can find it. jim
Valk Nov 15, 2010 07:10 PM
Done with a redirect
InfernoRedXfire Nov 15, 2010 09:18 PM
Way to go Jon! Great write up.
rcompart Nov 15, 2010 11:41 PM
Congrats on the install but not to rain on your parade, this was talked about in detail way back in '05 before I even got on this forum. I couldn't find the threads but there are quite a few of us that already have done this in our cars. Great feature though for sure and thanks for the new write up as searching for the one I found when I first joined yielded no results.
TimTim Jan 7, 2011 08:17 PM
OKC-XFR great write-up. I was able to find a mirror and will install tomorrow. Just a quick pair of questionw, you mentioned a switch to simulate reverse, where did you mount the switch and what type did you use.
Thanks and yes they are hard to get.
OKC-XFR Jan 8, 2011 11:19 PM
Thanks - I found the perfect switch, silver with an illuminated blue ring, but the place I ordered it from is taking forever to send it...I think it's time to find another source.
I plan on mounting it in the flat area just to the left of the garage door opener. I'll post pictures once I get the switch.
Bill F Jan 9, 2011 10:34 AM
Here is a source
http://www.autoanything.com/images/p...d9ff31fab72361
Gentex K2 Auto-Dimming Rear View Mirror
From $79.95
Free Shipping
Rating http://www.autoanything.com/images/r...4bc9c5957ed913 (62)
dtinker Jan 30, 2011 06:56 PM
OKC-XFR,
I looked but could not find an update on the Reverse simulation switch. You mentioned one with a blue light ring around it. I've got the mirror, but wanted to do the install all at once. where can I get this switch and do you have any details or pics on hookup /mounting?
Dave
dtinker
TimTim Feb 1, 2011 12:32 PM
I found a great switch but they are selling in lots of 40, but if you are interested here is the info, I am looking for a local source:
Switch RJS101-16L-F Metal dot illuminated
The switch has a changeover contact and an LED with a resistor. You have to decide what voltage you are sending to the switch and then choose this when deciding on switch type (eg 5V, 12V, 28V etc)
The MOQ of these is 40 parts and if you ordered for example RJS102-16LA-F-R-B-BS-12V-IP67 (12V LED switch, latching action, Blue Ring Illuminated LED, Brushed Steel Finish and sealed against water to IP67 standard) the unit price = $11.95 each + $45 shipping to USA.
RJS Electronics Limited
Grove Crescent House
18 Grove Place
Bedford
MK40 3JJ
United Kingdom
Tel. +44(0)1234 213600
Fax.+44(0)1234 210820
Web. www.rjselectronics.com
dtinker Feb 1, 2011 12:46 PM
Tim Tim,
Let me know if you find any of these locally. I don't need 40 of them, just one. I'll try looking around Houston too, will let you know if i find anything.
Dave
dtinker
dtinker Feb 1, 2011 02:08 PM
Tim Tim sent you a PM about switches.
Dave
dtinker
dtinker Feb 13, 2011 10:02 PM
Hey, got the Auto dimming mirror in this afternoon. Appears to be working ok. Have to drive it awhile to se if i need the reverse switch. Hardest part was getting old mirror off, then routing wiring under headliner edge.
Dave
dtinker
bluecoupe Mar 31, 2011 12:14 PM
Dave, when I did this a couple of years ago, I hooked up my reverse wire to the back-up light power wire and it has worked fine, no need for a switch.
© 2026 MH Sub I, LLC dba Internet Brands
