Fluid for Limited Automatic Transmission
Old Mar 6, 2011 | 11:38 AM
GuyWagon's Avatar
Default Fluid for Limited Automatic Transmission
Hello,
I have searched here and on the .net site for the proper fluid to use in the automatiic transmission for a Limited. I have found the Mercedes oil for the Sprinter vans at my local Dodge dealer. I am "OK" paying the $25.00 per quart but are there any less exspenive alternates?
Thanks
Guy Culbertson aka GuyWagon
Old Mar 6, 2011 | 12:23 PM
SparkieSRT6's Avatar
SSB SRT6 405hp/401Tq
Default Re: Fluid for Limited Automatic Transmission
Guy...you will find it cheaper than that and if you're willing to pay the $$$ then why compromise???
Old Mar 6, 2011 | 12:50 PM
Originally Posted by GuyWagon
Hello,
Thanks
From the repair manual.
TRANSMISSION FLUID
Shell
3403 Automatic Transmission Fluid (ATF) when new is red in color. The ATF is dyed red so it can be identified from other fluids used in the vehicle such as engine oil or antifreeze. The red color is not permanent and is not
an indicator of fluid condition. As the vehicle is driven, the ATF will begin to look darker in color and may eventually
become brown. This is normal. 3403 also has a unique odor that may change with age. Consequently,
Old Mar 6, 2011 | 09:44 PM
GuyWagon's Avatar
Just a matter of pricipal I guess. $25.00 per quart just grinds on me. I don't pay that much for transmission oil for Bell Helecopters or the jets that I work on and these are worth millions!!!
Guy Wagon
Old Mar 7, 2011 | 07:39 AM
paul1612's Avatar
you can useAmsoil Universal Automatic Transmission Fluid code ATF-QT
Old Mar 12, 2011 | 12:44 AM
willy's Avatar
That is what I plan on using, I have had good luck with it in my Land Rover too.
Old Mar 12, 2011 | 03:24 PM
bigblock427's Avatar
Shell ATF 3403
Mercedes-Benz spec = 236.10
Some more detailed specs:
Density at 15°C = 850 kg/m3 (DIN 51757)
Fla
sh point (Cleveland) = 190 °C (DIN ISO 2592)
Dynamic viscosity (Brookfield) at -40 °C =
16000 mPA s (DIN 51377)
Kinematic viscosity at 40°C =
33 mm2/s (DIN 51562)
Kinematic viscosity at 100°C = 7.2 mm2/s (DIN 51562)
Viscosity index (VI) =
195 (DIN ISO 2906)
Pourpoint =
-51
°C (DIN ISO 3016)
You can also use ATF oil from Bilstein Febi, Fuchs, Kroon ... that complies to the Mercedes-Benz 236.10 specifications.
Billto
16
Sep 1, 2016 11:06 PM
Dnivek
Aug 7, 2015 07:18 AM
Crossfireconv08
Jul 30, 2015 12:11 PM
Supperman
Jul 24, 2015 09:07 PM
chturner
Jul 24, 2015 04:47 PM
