Engine monitoring options?
Hi all,
I am looking into engine monitoring options. I have seen the guage pods but wanted to know if anyone knows of other options that will work in our cars. Is there a stereo head unit wit a pop up touch screen that can do a good job? I am looking for A/F ratio, IAT, and boost.
Hi all,
( $160)
very close to what you are looking for, however I don't see any A/F display ( fuel trim ? )
Gauges include:
Horsepower
Fuel Consumption Rate to 1/100th per gallon/liter
Vehicle speed (MPH)
Fuel Economy
Cost Per Mile/Cost Per Trip
Manifold Pressure (not available on some vehicles)
Battery Voltage
Engine Load
Coolant Temperature
Throttle Position
Intake Air Temperature
Ignition Timing
Engine Speed (RPM)
O2 Sensor Data
Fuel Trim
Hybrid Battery Charge (for Toyota Prius and Ford Escape)
And many more, depending on your vehicle's sensor design
Amazon.com: Auterra A-500 DashDyno SPD In-Vehicle Automotive Computer - Scan Tool, Performance Meter, and Data Logger: Automotive
pretty good price too. Some of the guys on this forum and some Eurocharged guys are using it. I can't afford the DashDAQ setup so this is my alternative.
That looks good but no wideband connection.
I would need wideband for the A/F ratio. I just called them and they said during set up it searches for wide band and if found will support and display wide band. If its only connection is through the OBDII port how would it find a wide band O2 sensor that I will have to add?
I'm still saving up for the Zeitronics dashdaq...I think it will be worth it in the long run....if all these other little mods would go away, I would be there by now...but, rear ends, and Uncle Sam have wiped me out again...dang it...
Latana, this may not include you but once you add all the other sensors, boost, fuel pressure, etc. it all adds up quick. DashDaq is the cream, but pricey for this cheapskate, lol. I had also thought you could add a wideband if needed to the DashDyno. Cheers
Kodebuster
Nov 5, 2020 04:06 PM
xfireohio
Jul 20, 2020 12:03 AM
Helot
Aug 15, 2015 04:19 PM
Dave Wilson
Jul 18, 2015 05:31 PM
