Car Turned Off While Driving, Engine Wont Crank
Old Sep 23, 2014 | 02:09 PM
Cedar11's Avatar
Default Car Turned Off While Driving, Engine Wont Crank
Hello all,
Left my house in my crossfire today after it had been sitting in the garage for 3 weeks. Car started just fine but just as i left my neighborhood it felt like the car was about to stall as i was accelerating between 20-40 mph.
I was a little worried but kept driving and sure enough the car died as i braked for a red light.
Now the engine doesn't even crank and when i have the key in the on position, the engine fan runs at full speed for some reason.
Any ideas? All help is greatly appreciated!
Car is 04 autostick with 80k miles. Battery is about 3 years old and needed a jump a few months ago.
Old Sep 23, 2014 | 02:23 PM
Cedar11's Avatar
Default Re: Car Turned Off While Driving, Engine Wont Crank
Also, coolant gauge is at the very bottom even though the fan runs at full speed
Old Sep 23, 2014 | 03:59 PM
It's your battery or alternator, most likely.
these cars do like to be jump started.
A weak battery would give you a wimpy engine.
Did you spoiler go up for no reason? a sure sign the battery is weak.
Old Sep 23, 2014 | 06:14 PM
Well, I will give a few ideas to look at and you can go from there. A weak battery can cause this to happen. Not enough juice, so to speak, to run the motor. There are other possibilities as well. But it could be as simple as the battery. If the battery doesn't fix it, then I would go to the Relay Control Module next. The RCM as we refer to it, has some bad solder joints that have to be re-soldered, and there is a "how-to" on here to help you with that. This condition usually happens after the motor is warm/hot from driving. Once it cools down, the car will sometimes start and run again. Let us know what happens....
Old Sep 23, 2014 | 07:29 PM
Cedar11's Avatar
Thanks for the response.
I pulled the fuse for the spoiler motor so it wouldn't have came up.
If the battery is weak then wouldn't it be unable to start the car just 10 minutes before?
Old Sep 23, 2014 | 07:30 PM
Cedar11's Avatar
Thanks i will look into the RCM...
Old Sep 23, 2014 | 07:37 PM
And don't overlook that the battery may be weak because the alternator is not charging it.
You want to see 12.5 volts with engine stopped, 14.3-14.8 with it running.
roychez
15
Aug 31, 2022 01:11 AM
blackpepper
16
Jun 2, 2015 12:50 PM
WindRestrictor
Jun 1, 2015 02:31 PM
crossfiretech
Sep 25, 2003 08:14 PM
mouserider
Jul 20, 2003 03:42 AM
