2005 coupe cranks but won't start.
Old Oct 17, 2015 | 05:52 PM
Dnivek's Avatar
Default 2005 coupe cranks but won't start.
My car had been running fine, parked it for a few weeks. Tried to start it today and it cranks over but won't fire. I suspect CPS but I also see posts that SKREEM is possibility. Is there a easy way to tell the route I should take?
Old Oct 17, 2015 | 07:13 PM
Mrmiata's Avatar
Default Re: 2005 coupe cranks but won't start.
Skreem.. 3 cranks.. "stutter starts" and dies.. (sometimes 2) .. Must then pull battery cable to find the process only repeats itself.
Old Oct 17, 2015 | 07:17 PM
Yea, the SKREEM is like baseball, 3 strikes and you're OUT, whereas a bad CPS or connector will let you try till the battery goes dead.
This same symptom has also been traced to a faulty fuel relay in the RCM module, but you can test for fuel pressure at the test point on the fuel rail at the front passenger side of the engine.
If you can find one of those old fashioned neon plug testers, you can stick it in one of the coil packs where you have pulled a plug wire. If you see it light up, then it's almost for certain you have a fuel issue.
If it does not light up, then the PTCM is not happy with SOMETHING, like the CPS, or the SKREEM is telling it that the car is being stolen.
Old Oct 17, 2015 | 07:27 PM
Dnivek's Avatar
Ok, I've tried starting it five or six times and it still cranks, just no go. Doesn't even attempt to fire. So No SKREEM in that case right?
I've re soldered the No Start issue back when I purchased the car, so it should all be rock solid. I hope it's as simple as CPS do I can get this thing out of the garage and driving again...
Old Oct 17, 2015 | 07:43 PM
Mrmiata's Avatar
Not the skreem is a definite ...
Old Oct 21, 2015 | 06:15 PM
Dnivek's Avatar
Replaced CPS today with Bosch unit, still won't start. Cranks and cranks, won't even stutter. Any ideas?
Old Oct 21, 2015 | 06:42 PM
Pull a plug wire and insert a phillips head screwdriver in the end, hold it ( by the plastic handle ) so the shaft is about
the thickness of a nickel from the block, have someone crank it.
If you have spark, then the PTCM is happy with the CPS and WANTS the engine to run.
If no spark, then I'm kinda at a loss since so many factors are involved on the PTCM inputs.
Lets HOPE there is spark, and if there is, then take the cap off the test point on the fuel rail at the front passenger side of the engine,
use a rag to prevent too much spillage and depress the little tire valve looking thingey,
you should get a good squirt since there should be about 60 PSI there.
If nothing, then do same thing with engine cranking over.
NOTE: kneel down with your ear just in front of the passenger rear tire and see if you can hear the fuel pump running when someone turns on the ignition ......
Report back results.
Old Oct 21, 2015 | 06:45 PM
Dnivek's Avatar
May have an idea... I just realized ism not hearing the traditional hum when I turn the key to on. Bad fuel pump?
Old Oct 21, 2015 | 07:10 PM
Bad pump, blown fuse or bad fuel pump relay in the RCM.
Old Oct 21, 2015 | 08:21 PM
Mrmiata's Avatar
Was just fixing to go there..
Along with ala_xfire 's thoughts..
Old Feb 2, 2018 | 11:05 AM
garyt's Avatar
I just had the same issue with my 05. Intermittent - Would crank fine but not start until the 2nd or 3rd attempt. Turns out I had a bad battery. Installed new battery and it starts up every time.
Old Feb 2, 2018 | 12:25 PM
This photo is obsolete and you have the new one.I just saw this is an old thread.
Travish
Nov 19, 2015 01:48 PM
Zoodust
Oct 22, 2015 01:04 PM
ala_xfire
Crossfire Events and Meets
Oct 18, 2015 04:13 PM
+fireamx
Oct 18, 2015 12:54 AM
Display_Name
Oct 14, 2015 10:55 PM
