Cleaning the headlight assembly? Help!
Old Oct 24, 2015 | 12:12 PM
SeanOldaker's Avatar
Default Cleaning the headlight assembly? Help!
So I've tried everything from sanding to buffing and even tried the headlight cleaning stuff from oriellys, and they still look like crap, anyone have any suggestions on how to clean them? Thanks!
Old Oct 24, 2015 | 01:23 PM
maxcichon's Avatar
Default Re: Cleaning the headlight assembly? Help!
Have you tried cleaning the inside?
Can you take a closeup photo?
Old Oct 24, 2015 | 02:24 PM
How do I get the lens off?
Old Oct 24, 2015 | 06:49 PM
Travish's Avatar
You don't...well you can but it's not worth it.
https://www.crossfireforum.org/forum...-assembly.html
Old Oct 24, 2015 | 07:33 PM
It's not yellow it's just a layer of white-ish stuff along the top half of the assembly
Old Oct 24, 2015 | 07:48 PM
maxcichon's Avatar
Aaaahhhh-the info I needed.
I hate to say this, but, your headlights just need a more...aggressive...sanding.
Here's a video :
This fella is a bit sloppier-and faster-than I am, but it's a good guide.
I've had to start with P500 and work up from there with a few badly sun-damaged lenses. If you sand, then dry, and you can still see the horizontal cutoff line of damage, do it again.
That 1st .003" is some very tough material applied during manufacturing. You can't polish it-you can merely remove it.
I'm starting to lean toward what many here promote: Clearcoating them once you are happy with the clarity. Here's a video, but there are some contradictions with the 1st video.
Go for it!:
Old Oct 24, 2015 | 07:51 PM
I tried that but I started with 1500 grit so I guess I'll just try again with a lower grit, thanks though!
Old Oct 24, 2015 | 11:52 PM
maxcichon's Avatar
One last thought-the "line" will move gradually "down" the face of the lens as you remove the protective coating. It's a sign of progress? Kinda'?
Old Oct 25, 2015 | 07:25 AM
Ky06coupe's Avatar
Mine looked even worse than yours, now here is what they look like after sanding like crazy (the lenses were pretty much opaque at that point), and then a few layers of clearcoat.[IMG]MKKTU1v.jpg[/IMG]
Old Oct 25, 2015 | 08:05 AM
maxcichon's Avatar
Originally Posted by Ky06coupe
Mine looked even worse than yours, now here is what they look like after sanding like crazy (the lenses were pretty much opaque at that point), and then a few layers of clearcoat.[IMG][/IMG]
Bingo!
Fixing these (any, really) to make them look as-new is just a matter of having the guts to start off making them look terrible!
Old Oct 25, 2015 | 09:46 AM
How are you guys getting them out? Do you absolutely have to take the bumper off? Mine will not budge and I live in a apartment complex so my landlord will flip out if she see my bumper and stuff laying beside my car, (technically not aloud to do car matainence here because it "makes the parking lot look trashy")
Old Oct 25, 2015 | 11:43 AM
maxcichon's Avatar
You really do NOT need to remove them. Buy a couple of rolls of blue painters tape, put 3 layers around the edge to protect the paint and be careful.
If you start to lift an edge of the tape, re-apply.
No worries, mate.
Old Oct 25, 2015 | 12:29 PM
Thanks guys I really appreciate it! And has anyone painted the inside of the assembly? I wanted to redo the black, make it more of a gloss black
Old Oct 25, 2015 | 04:00 PM
Travish's Avatar
Some here have done that but you have to split the headlight like when you want to install angel eyes or halos. You will need to dremel the lenses open and reseal. I have read the heating in the oven thing wont work on ours.
Old Oct 25, 2015 | 05:54 PM
steps's Avatar
jUST HAD MINE DONE FOR $35 A PIECE CAME OUT GREAT ECOTECH JACKSONVILLE FL.
smfrycruzr
Jul 17, 2023 05:33 PM
srtmodder
Aug 23, 2017 08:28 PM
epeterh
Northwest Forum
Oct 7, 2015 12:43 AM
pioneer4x4
Sep 24, 2015 11:17 AM
ChrisA
Aug 17, 2015 09:54 PM
