crossfire roof problem
hi im new to this site and have a problem with my crossfire roof not working.Ive researched quite a bit about it but cant seem to find a solution.Really need some help and advice would be much appreciated.When the hood is relased at front and lifted the windows drop and the led on the switch changes from flashing to constant.I presume next the bow latch should release the hood,but all im getting is the pump running trying to open the hood.If i stow the hood away via the emergency routine the system works fine and closes it through the proper procedure.Thanks inanticipation.Hope someone can help.
