Cabin Heater not hot questions
Old Jan 6, 2019 | 03:46 PM
Tom3120's Avatar
Default Cabin Heater not hot questions
Ok, so I replaced my water pump and thermostat yesterday. Let it sit overnight so sealant would be good and dry for today. Just went out and added 2 gallons of distilled water just to check for leaks. NO LEAKS! Started and ran the car at idle for about 15 minutes with the cabin heater turned up full blast and temp dials on both sides turned up all the way. Temperature gauge got up to the normal range (about half way) but the air blowing in the cabin did not feel warm. I'm in a garage, about 45 degrees out side, hood up on car with the cowl off. Windows of the car are both down. I never saw the radiator fan come on. Why isn't the air blowing warmer inside the cabin?
I plan to drain out some of the water and add Zerex G-05 antifreeze to a final mixture of 50/50. Once I'm sure I have no leaks but that looks good so far.
I should note that I had good heat blowing in the cabin before.
Old Jan 6, 2019 | 04:00 PM
Mrmiata's Avatar
Default Re: Cabin Heater not hot questions
Sounds like your "dual climate" control valves are sticking.. plenty on the forum about those if you do a search.
Old Jan 6, 2019 | 04:07 PM
Tom3120's Avatar
I had good warm heat before changing the pump. Wondering if I just don't have enough fluid in the system yet as I only added 2 gallon wich is almost a gallon short of capacity although the reservoir tank still is half full.
Old Jan 6, 2019 | 04:29 PM
Tom3120's Avatar
As llong as the temperature stays in the good range can I assume that the new thermostat is opening as it should?
Old Jan 6, 2019 | 04:40 PM
With so much missing there is probably a large air lock, those valves are more or less at the highest point in the system.
Is the header tank half full with water or old antifreeze?
Fill it right up with distilled water, run it and top it up again if required. I would then drain it all again which would remove more old antifreeze.Then do what you have to do to get the 50/50 mix. There is a good PDF by James1549 on renewing the antifreeze, you should read it.
Old Jan 6, 2019 | 04:50 PM
Tom3120's Avatar
So I decided to take the car for a short drive and as soon as I got about a block away the air started to blow out very warm. So it seems all is good now. Tomorrow I’ll drain out some of the water and add in the antifreeze.
Old Jan 6, 2019 | 04:57 PM
I can see that we have to give you some time after your posts to let you add new info or think about the problem more before adding our two cents.
Old Jan 6, 2019 | 05:19 PM
Tom3120's Avatar
180, I appreciate all the advice I get here. I also try to think my own way through problems. I don’t want to be someone who can’t think for myself, but I’m also not too proud to ask for help. In the end I think you were correct in the fact that the system was probably low and had air in it.
Frankenmerc
20
Dec 13, 2025 11:51 PM
tighed1
Jul 2, 2011 04:38 PM
Electric Messiah
Feb 25, 2010 01:53 PM
Stogey
South Forum
33
Sep 12, 2009 08:46 AM
PEREZE333
Jul 2, 2004 04:19 PM
