Cross fire won't start
Hi I have a 2005 Cross fire I have changed the crankshaft sensor and cam shaft sensor and rcm and it still won't start all lights are inside car battery is new ,not sure what to do next
Thanks |
Re: Cross fire won't start
What exactly does it do / not do when you try to start it? Have you tried disconnecting the negative battery cable for 5 minutes and re attaching?
Originally Posted by ZERACER
(Post 941926)
So it doesn't do anything? Can you hear the fan kick in when you try to start? If so it is probably the RCM.
(Post 941935)
Sounds like the RCM.
(Post 941971)
Does anything happen if you disconnect the negative battery cable for 5 minutes, then reattach and turn the key?
Originally Posted by Gclcjc
(Post 941927)
The engine does not turn over but all light on the dash are on and the key fob works.
Some mean the engine does not rotate at all and some mean it rotates but does not start and run. What is your meaning? |
When you turn the key the dash lights come on and nothing else happens.
You are confusing things with multiple postings. Have you tried replacing the RCM, relay control module? Have you scanned for codes?
Sorry for the confusion. Will try RCM this weekend. When checking 1 of the fuses it now won't fit back into the slot. The connection slid down inside of the fuse box, so the fuse won't go back in now
| All times are GMT -4. The time now is 11:14 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
