ECM 2006 Chrysler Crossfire
Hello,
Is 2006 Chrysler Crossfire ECM the same computer for the A/T and M/T (other then the programming)? John |
Re: ECM 2006 Chrysler Crossfire
Helloi
Yes ECM the same, but software inside are different. Will need a Ktag for exemple for change the software Will need to change the eeprom files for the key to (in the ecm), car location (US car have an extra calister purg vavle etc ..) So yes ECU are the same (with other car, need to check ECU compatibility). On my side I test ECU SLK 320 A/T, ECU S350A/T and ECU ML A/T on my Crossfire M/T Need to check ECM number compatibilty on this link https://bed.kmtech.fr/ Take care, compatibity OK, but job to change all software inside are not so easy ... Nicolas |
Originally Posted by IJLDC1
(Post 983821)
Hello,
Is 2006 Chrysler Crossfire ECM the same computer for the A/T and M/T (other then the programming)? John Josh Chase at "The Mercedes Swap Shop". Rob at Needswings.com. Many SAY they know what they are talking about, these two have demonstrated they can actually DO the work. |
(Post 983821)
Hello,
Originally Posted by nicolas-e63
(Post 984100)
Helloi
Yes ECM the same, but software inside are different. Will need a Ktag for exemple for change the software Will need to change the eeprom files for the key to (in the ecm), car location (US car have an extra calister purg vavle etc ..) So yes ECU are the same (with other car, need to check ECU compatibility). On my side I test ECU SLK 320 A/T, ECU S350A/T and ECU ML A/T on my Crossfire M/T Need to check ECM number compatibilty on this link https://bed.kmtech.fr/ Take care, compatibity OK, but job to change all software inside are not so easy ... Nicolas ktag doesnt allow you change software. You dont need to change empromm because if you damage the data you lose everything. he better off sending to us at the MSS, most of the time people dont need ecus |
