CrossfireForum - The Chrysler Crossfire and SRT6 Resource (https://www.crossfireforum.org/forum/)
-   Troubleshooting & Technical Questions & Modifications (https://www.crossfireforum.org/forum/troubleshooting-technical-questions-modifications/)
-   -   Won't Start and Speedometer says Oil High Light. (https://www.crossfireforum.org/forum/troubleshooting-technical-questions-modifications/88895-wont-start-speedometer-says-oil-high-light.html)
Tre'Louis Apr 24, 2026 01:16 AM
Hey Y'all, I haven't been on here in a min. I was driving my crossfire and in the speedometer. It will beep with the oil sign, and it says high. The thing is I have oil in the engine, and I have coolant in the car, unfortunately. I have to send the skreem, ecu mods back in as well to get reset. Because ruby won't start. Did anyone else have this problem? What do I do?
zip439 Apr 24, 2026 08:18 AM
Re: Won't Start and Speedometer says Oil High Light.
@Tre'Louis
Look at the dip stick and check your oil level. You probably over filled. You can use a vacuum pump and remove some oil through the dipstick tube.
Not starting is an entirely different problem which it appears you have already dug into. Best to stop digging and start from the basic of a non start.
Turn on your headlights. Disconnect the negative battery cable for three minutes. Reconnect the battery cable. Turn off the headlights.
Does the car crank, turn over when you try to start the car?
Does the car do nothing when you try starting; not even crank or turn over ? After attempting to start leave the key in the ignition switch an naturally spring back to the on position for a minute. DO NOT turn the key to the off position. Does the fan speed up and become very loud?
Does the car attempt to start twice turn over but starts for just a sec then dies before not turning over at all???
We need more information to help you get the car running.
PS WHERE IN THE WORLD DO YOU LIVE??? YOU MAY JUST HAVE A NEIGHBOR WHO IS WILLING TO HELP YOU SORT THIS OUT.
© 2026 MH Sub I, LLC dba Internet Brands
