TSBs and service bulletins retrieved for 2005 Xfires - NHTSA
Go to the service bulletin part of the NHTSA and you will pull up the following for 2005's. Didn't run 2004's. Formatting gets screwed up here. Looks much better at nhtsa.gov site.
http://www-odi.nhtsa.dot.gov/cars/pr.../tsbsearch.cfm Make : CHRYSLER Model : CROSSFIRE Year : 2005 Manufacturer : DAIMLERCHRYSLER CORPORATION Service Bulletin Num : 0800306 Date of Bulletin: JAN 18, 2006 NHTSA Item Number: 10019250 Component: ELECTRICAL SYSTEM Summary: INSTRUMENT CLUSTER INITIALIZATION. *TT Check to Request Research. Submit below. Make : CHRYSLER Model : CROSSFIRE Year : 2005 Manufacturer : DAIMLERCHRYSLER CORPORATION Service Bulletin Num : 19 Date of Bulletin: JAN 01, 2006 NHTSA Item Number: 10019269 Component: ENGINE AND ENGINE COOLING: COOLING SYSTEM:FANSummary: THE RADIATOR COOLING FAN MOTOR MAY HAVE BEEN IMPROPERLY ASSEMBLED. CUSTOMER SATISFACTION NOTIFICATION E19 RADIATOR COOLING FAN MODULE. *TT Check to Request Research. Submit below. Make : CHRYSLER Model : CROSSFIRE Year : 2005 Manufacturer : DAIMLERCHRYSLER CORPORATION Service Bulletin Num : 2100205 Date of Bulletin: MAY 07, 2005 NHTSA Item Number: 10012339 Component: POWER TRAIN:AUTOMATIC TRANSMISSION Summary: TRANSMISSION FLUID MAY BE WICKING IN THE RIGHT FRONT CORNER OF THE TRANSMISSION OIL PAN AREA. *EH Check to Request Research. Submit below. Make : CHRYSLER Model : CROSSFIRE Year : 2005 Manufacturer : DAIMLERCHRYSLER CORPORATION Service Bulletin Num : 2100204 Date of Bulletin: FEB 05, 2005 NHTSA Item Number: 10006447 Component: POWER TRAIN:MANUAL TRANSMISSION Summary: FIRST GEAR SYNCHRONIZER ENHANCEMENTS. *TT Check to Request Research. Submit below. Make : CHRYSLER Model : CROSSFIRE Year : 2005 Manufacturer : DAIMLERCHRYSLER CORPORATION Service Bulletin Num : 0800905 Date of Bulletin: FEB 05, 2005 NHTSA Item Number: 10012804 Component: ELECTRICAL SYSTEM Summary: PNEUMATIC LOCK HOSE REPAIR KIT AVAILABLE. *TT Check to Request Research. Submit below. Make : CHRYSLER Model : CROSSFIRE Year : 2005 Manufacturer : DAIMLERCHRYSLER CORPORATION Service Bulletin Num : 2300405 Date of Bulletin: JAN 28, 2005 NHTSA Item Number: 10012257 Component: STRUCTURE:BODY Summary: DOOR GLASS MISALIGNMENT OR CONTACTS THE ROOF. *TT Check to Request Research. Submit below. Make : CHRYSLER Model : CROSSFIRE Year : 2005 Manufacturer : DAIMLERCHRYSLER CORPORATION Service Bulletin Num : 0800205 Date of Bulletin: JAN 13, 2005 NHTSA Item Number: 10012333 Component: ELECTRICAL SYSTEM Summary: HEADLAMP CONDENSATION. *EH Check to Request Research. Submit below. Make : CHRYSLER Model : CROSSFIRE Year : 2005 Manufacturer : DAIMLERCHRYSLER CORPORATION Service Bulletin Num : 2100105 Date of Bulletin: JAN 06, 2005 NHTSA Item Number: 10012316 Component: POWER TRAIN:AUTOMATIC TRANSMISSION Summary: GEAR GRIND LIKE SOUND WHILE SHIFTING. *EH Check to Request Research. Submit below. Make : CHRYSLER Model : CROSSFIRE Year : 2005 Manufacturer : DAIMLERCHRYSLER CORPORATION Service Bulletin Num : 0804304 Date of Bulletin: DEC 18, 2004 NHTSA Item Number: 10011926 C omponent: EXTERIOR LIGHTING:HEADLIGHTS Summary: HEADLAMP CONDENSATION. *TT Check to Request Research. Submit below. Make : CHRYSLER Model : CROSSFIRE Year : 2005 Manufacturer : DAIMLERCHRYSLER CORPORATION Service Bulletin Num : 0200904 Date of Bulletin: DEC 16, 2004 NHTSA Item Number: 10011939 Component: SUSPENSION Summary: SQUEAKING SOUND FROM FRONT SUSPENSION. *TT Check to Request Research. Submit below. Make : CHRYSLER Model : CROSSFIRE Year : 2005 Manufacturer : DAIMLERCHRYSLER CORPORATION Service Bulletin Num : 2305104 Date of Bulletin: DEC 06, 2004 NHTSA Item Number: 10011938 Component: STRUCTURE:BODY Summary: LIFTGATE BUMPER FASTENER WILL NOT TIGHTEN. *TT Check to Request Research. Submit below. Make : CHRYSLER Model : CROSSFIRE Year : 2005 Manufacturer : DAIMLERCHRYSLER CORPORATION Service Bulletin Num : 0200804 Date of Bulletin: NOV 08, 2004 NHTSA Item Number: 10011548 Component: SUSPENSION Summary: RATTLE SOUND FROM REAR. *TT Check to Request Research. Submit below. Make : CHRYSLER Model : CROSSFIRE Year : 2005 Manufacturer : DAIMLERCHRYSLER CORPORATION Service Bulletin Num : 2304203 Date of Bulletin: OCT 18, 2004 NHTSA Item Number: 10010532 Component: STRUCTURE:BODY Summary: DECKLID WILL NOT OPEN. *EH Check to Request Research. Submit below. Make : CHRYSLER Model : CROSSFIRE Year : 2005 Manufacturer : DAIMLERCHRYSLER CORPORATION Service Bulletin Num : 0803004 Date of Bulletin: SEP 02, 2004 NHTSA Item Number: 10010480 Component: ELECTRICAL SYSTEM Summary: ONE OR BOTH KEYLESS ENTRY TRANSMITTER DO NOT WORK. *TT Check to Request Research. Submit below |
Re: TSBs and service bulletins retrieved for 2005 Xfires - NHTSA
Great find Brother... hooah
