How do I Jack up my XFire with a FLOOR JACK???
Old Jun 3, 2020 | 02:54 AM
  #41 (permalink)
phil alvirez's Avatar
Default Re: How do I Jack up my XFire with a FLOOR JACK???
post 35:
"Jack the entire rear up by placing the jack under the pumpkin ( differential ) then put the stands under the jack points.
Lower jack then go in from the middle of the car to the front center where you see cross member join and jack up front there.
Place stands under front jack pads and Bob's your uncle! "
after studying your post i have some doubts:
regarding this: " then go in from the middle of the car to the front center where you see cross member join and jack up front there."
could you please elaborate?
i lift the car from the differential. this i understand. it is easy to identify.
then i place stands at the 2 rear hard points. right?
but, "go in from the middle of the car". does it mean that you slide the jack between the front and rear wheels and then push it forward?
if so, how far forward? " to the front center where you see cross member join"? could you be more specific? perhaps a picture of the underneath would do?
i want to make clear that all that you do and say is highly appreciated. it is just that with a car so sophisticated, sometimes is hard to find anything among so many things.
perhaps this pic may help? https://howtune.com/articles/204-rep...ire/image-4218
i guess is that hole between the 2 bolts that hold the diagonal reinforcement straps, right?
thanks again for all of this.
Old Jun 3, 2020 | 03:22 AM
  #42 (permalink)
I use M-B jack adapters that locate directly into the jacking blocks on the Crossfire. If I need to get under the car, I'll use 2 floor jacks (I've got 4) to raise the side of the car. Instead of jack stands, I put 8x8 wooden blocks stacked 2 high to provide safety support. Don't like jack stands - too dangerous. IMO
thank you for your input.
but am confused
this is another subject that is worth exploring.
you say that you dont trust jack stands to provide safety support..
others say that they dont trust jacks for that.
could you experts discuss this and reach an understanding?
thanks
Old Jun 4, 2020 | 03:22 PM
  #43 (permalink)
there are jacks that have an extra safety. there is a bar that you insert when at the highest position so there is no way that it may fail.
an example is this:
Amazon Amazon
this way a jack works also as a stand and we can have the best of both worlds.
Old Jun 4, 2020 | 07:48 PM
  #44 (permalink)
ambidextrous's Avatar
an example is this: https://www.amazon.ca/Powerbuilt-620.../dp/B00OCIBPIM
That's a very expensive jack!
Old Jun 4, 2020 | 09:27 PM
  #45 (permalink)
indeed, but that was just an example.
the 1 i got is this: https://www.princessauto.com/en/detail/2-ton-xtra-low-profile-floor-jack/A-p8486698e
that also has the same feature.
that is $130 canadian ( some us$ 100). and didnt have to pay shipping.
(and is low profile).
Old Jun 5, 2020 | 12:03 AM
  #46 (permalink)
Wink Re: How do I Jack up my XFire with a FLOOR JACK???
that is $130 Canadian ( some us$ 100). and didn't have to pay shipping.
Okay, I assume you will want to support your Crossfire at four points when you raise it: With only $520 (Canadian), four "gadget jacks" will do the job, and you don't even have to pay shipping costs!
Another poster on this thread mentioned using 8 inch thick wood blocks in lieu of jack stands, and I think that's a cheap & safe alternative - and they will stack neatly when not being used. Now, if you buy one jack for $130 (Canadian), you'll have $390 left to buy a few wood supports and throw a pretty nice party for your friends.
Old Jun 5, 2020 | 01:17 AM
  #47 (permalink)
JSK's Avatar
JSK
I’m kind of partial to my quick jack.
Old Jun 5, 2020 | 05:03 AM
  #48 (permalink)
there are many alternatives. and i did not sugest 4 of those. if you think about it, just 1 can do for lifting, and for supporting, the cheapest way is wood blocks, as you say.
or 2 sets of stands.
i got these: https://www.princessauto.com/en/deta...ds/A-p8760696e (canadian $).
the point is to compare supporting with jacks or stands for safety.
and of course, low jacks are more expensive than regular, but as these cars are low, hence the need.
Old Jun 5, 2020 | 07:31 AM
  #49 (permalink)
waldig's Avatar
Talking Re: How do I Jack up my XFire with a FLOOR JACK???
Jack up the car and put steel ramps under the tires, takes some work but it is safe and solid, Woody
Old Jun 5, 2020 | 02:06 PM
  #50 (permalink)
twanger's Avatar
Made additional custom ramps out of pcs of 2 x 10's that lock into holes of purchased steel ramps creating an acceptable angle to drive the car on ( or back on) . Then if needed , jack up rear under the pumpkin & use 2 stationary jacks under rear pads for safety . The car is safely elevated .
I find the recent 3 ton Harbor Freight 3 1/8 " minimum height floor jack very handy for $100 . It has dual lift cyls & goes up fast .
Old Jul 27, 2020 | 12:13 AM
  #51 (permalink)
Brian P's Avatar
Okay, so, I’ve read that the jack stands at Harbor Freight have weld failures. Can anyone recommend a good jack to lift mine up (is Harbor Freight okay for a good, low profile one)? There are a bunch on Amazon, but, I’m just looking for what’s going to work without breaking the bank. I appreciate suggestions as I have a few things to tackle this week on the car. Thanks!
Old Jul 27, 2020 | 01:08 AM
  #52 (permalink)
Brian P's Avatar
Old Jul 27, 2020 | 09:59 AM
  #53 (permalink)
First off, a jack stand does not lift a car, it supports it after a jack lifts it.
Look for jack stands that have a safety locking pin.
Look for a jack with low profile and fast raise.
edit - ( SORRY, I missread your post - ignore what I first said, the pictures are still valid. )
Old Jul 27, 2020 | 10:00 AM
  #54 (permalink)
twanger's Avatar
I not long ago bought the H F dual cyl 3 1/8" clear specifically for our CF for $100 on sale . Works great . I have a bunch of their stationary jacks , some w/ in the bad s/n group & some not . Have 4 supporting a 38 Ford coupe for yrs & not going to mess w/ them .
However , by no means am I condoning use or purchase of these jacks .
Also made extenders for my metal drive on ramps out of 2x10 pcs producing a gradual incline accepting the CF .
Old Jul 29, 2020 | 04:49 AM
  #55 (permalink)
Brian P's Avatar
I appreciate the response, guys. I found a couple of aluminum stands & a low profile jack at Harbor Freight.
Old Feb 16, 2023 | 06:18 PM
  #56 (permalink)
MountainGoat's Avatar
Originally Posted by LARRYG36
Seriously, Do i have to make a custom Interface Block like the one on the piece of S**T Jack that the car comes with ????
Coming back to the original question: has anyone fabricated the white nylon end from the Crossfire jack onto a hydraulic floor jack?
Old Feb 17, 2023 | 07:53 AM
  #57 (permalink)
There are lots of M-B Jack Pads available that can be used with a Hydraulic Floor Jack. I've probably got a dozen or so, both aluminum & rubber, in my garage cabinet that I've used. I typically use smaller 2-3 ton Floor Jacks just because the lifting pad is smaller which makes it easier to position under the Crossfire's lifting point with a Jack Pad Adapter.
But if you're asking about one that works with a Hydraulic Bottle Jack, hardly any are available. However, looks to me that you could use a low profile M-B Jack Pad (metal versions are typically a lower overall height than the rubber versions) that would fit into the car jacking points. Then if you use a Bottle Jack Pad Adapter mounted to the jack's shaft, you could position this under the M-B Jack Pad & lift the car. Bottle Jack would have to be a stubby or low profile version as there isn't much space under the Crossfire rocker panel. I looked around last night for a M-B Jack Pad designed for a bottle jack but never was able to locate one.
CLICK"><span style=CLICK" /> CLICK">CLICK
Old Feb 17, 2023 | 08:21 AM
  #58 (permalink)
I did find this M-B Jack Pad Adapter that is designed for use with either a Floor Jack or Jack Stand. Never saw this before - kinda interesting! Not sure if it fits the lifting point on our R170 chassis.
CLICK
Old Feb 17, 2023 | 10:52 AM
  #59 (permalink)
UrbanE's Avatar
Are you using Jack stands in conjunction with the Jack?
if yes there are two great stand options for our mounting pads.
Old Feb 17, 2023 | 11:47 AM
  #60 (permalink)
When I jack up my car to take off a wheel to get at the brakes etc, I always put the wheel under the door sills outside up and then add some wood to fill the gap as much as possible.
I do not trust the welded jack stands that I have and have never used them. I have never had need to jack up either of my Crossfires, so the question has never arisen.
When I changed the engine in a GMC Cargo Van in the early 90s I used 4 x 4s x 12” long cross stacked on each corner, it was as steady as the Rock of Gibraltar and l had no fear of going underneath.
