Wiper Arm
Hey guys I'm needing to take off the wiper arms on my crossfire so I can then take off the cowl. I've searched everywhere but can't find anything. I thought all I had to do was take off the nuts that are on them and they would pop right off right? Any help is appreciated.
Re: Wiper Arm
You need a small gear puller or a steering wheel puller.
Re: Wiper Arm
Re: Wiper Arm
Any automotive store.
Re: Wiper Arm
Just be careful not to pull so hard that you hit the underside edge of the hood with the wiper arm when it comes off. Works for me. |
Re: Wiper Arm
I don't mean to hijack this thread but do one of you guys happen to know where I can get the covers for the wiper nuts or what size they are then maybe I can find some covers ?? :confused:
THANKS Howard :cool: |
Re: Wiper Arm
wiper caps chrysler part# 5101489AA , benz part# A0008240249 about $3.00 to $6.00 for one plus shipping, or from your dealer in your area, there is a new member on the forum who can get the parts for us but cant think of his screen name ? I will look, took a look and found BLK04LMTD is his screen name, I thinks he works at a dealer not sure PM him and see what happens.
Re: Wiper Arm
That would be awsome and thanks for the info ,,thats what makes this forum one of the best on the web :D you can always find someone to help with info,,
Howard :) |
Re: Wiper Arm
1 Attachment(s)
I bought a package of 6 from OEDiscountParts.com (see attached correspondence with Mike Lewis). Chrysler P/N is typically out of stock or back ordered. They know to purchase under M-B P/N, which in this case is cheaper! I had them within a couple of days. When you do P/N search for M-B, leave the 'A' off the P/N. Here's another tip. I had the DS cap pop off whenever I washed the car. The first few times, I didn't know it happened but found the cap in the driveway later on. I asked this forum what to do. FP told me to put a small piece of electrical tape (I used smooth) along a portion of the cap. I had to trim the piece to to make it work the way I wanted. Cap then is a little tight to insert; had to move it back & forth to get it to seat properly. And guess what - it stays! Way to go FP! |
Re: Wiper Arm
Here's another tip. I had the DS cap pop off whenever I washed the car. ! For the life of me I don't get it.:confused: |
Re: Wiper Arm
I have to ask, DS cap?
Re: Wiper Arm
Originally Posted by Blast Chamber
Driver's Side
Re: Wiper Arm
You can also apply downward pressure on the arm at the pivot joint near the rotating spline. This will cause the small section mounted to the spline to flex and it will 'pop up' off the spline. While still exerting the downward pressure with your left hand, you can pull off the wiper arm by using your right hand to pull up the splined mount.
Just be careful not to pull so hard that you hit the underside edge of the hood with the wiper arm when it comes off. Works for me. You would not want to use a puller on the type you are talking about as a latch bites into the spline until you remove the grip as you describe. |
Re: Wiper Arm
These are not that type, they need a battery terminal puller or similar. The puller is used after the cap and nut have been removed.
Re: Wiper Arm
It depends on how tight they are on! I my self have tried both methods and yes it does work, although you do want to be carefull when rocking the arm back and forth as too not cause any damage to the wiper trans/linkage and pivot, I know this because I broke a pivot assembly right off and then had to replace the whole assembly (different car) and when using a puller install the nut back on the shaft so that it keeps it centered so you dont damage the threads in case it slips off. You can also use some of that windsheild butyl stuff to keep your caps on, like rope caulk or simular, it stays tacky and you can still remove the caps fairly easy.
Re: Wiper Arm
1 Attachment(s)
Help! What am I doing wrong? My alarm started going off at random so I am trying to replace the siren and can't get the whiper arms off. I tried using a small gear puller. See attached pic. Is there something I am missing?
Re: Wiper Arm
Should pop right off, if need be, keep a little tension on it, then take a small hammer, an lightly tap the stem of the puller. It looks like the puller is not straight, up an down(pulling on an angle)
Re: Wiper Arm
I have removed the wiper arms on several Crossfires.
I found that all I had to do was remove the nut and rock them up and down and they came loose easily. |
Re: Wiper Arm
A little penetrating oil wouldn't hurt either
Re: Wiper Arm
Originally Posted by ZERACER
(Post 863281)
The blade on my wifes car flew off when it was raining hard the other week, fortunately I was coming to a stop at the time. The latch had not snapped in place properly when I put it on and it lasted a few months like that. Luckily I was in the car, my wife would have come home with an arc scratched into the glass.:rolleyes: |
